SolarWinds Failover Engine
This template assesses the status and overall performance of a SolarWinds Failover Engine server.
Prerequisites
WMI access to the target server.
Credentials
Windows Administrator on the target server.
Component monitors
To learn more about default component monitors included in SAM, see SAM online help.
Service: SolarWinds FoE SCOPE Data Collector
This monitor returns CPU and memory usage of the Failover Engine cope Data Collector service, which collects and stores configuration and performance data.
Service: SolarWinds FoE Server
This monitor returns CPU and memory usage of Failover Engine.
Current Throughput
This monitor returns the current throughput via the CommsMgr in MBits/sec.
KB Dispatched from Receive Queue
This monitor returns the number of KB data applied from the Receive Queue. This is only available on the passive server.
This component has Count statistic as difference enabled. It will return the difference between two polling intervals.
KB Dispatched from Send Queue
This monitor returns the number of KB data sent from the Send Queue. This is only available on the active server.
MegaBytes Received
This monitor returns the number of MegaBytes received across all channels.
MegaBytes Sent
This monitor returns the number of MegaBytes sent across all channels.
Messages Received
This monitor returns the individual messages received by CommsMgr.
Messages Sent
This monitor returns the individual messages sent by CommsMgr.
Oldest Receive Update Queue Entry
This monitor returns the age of the oldest Receive Update Queue entry in milliseconds.
Oldest Send Update Queue Entry
This monitor returns the age of the oldest Send Update Queue entry in milliseconds.
Receive Queue Drain Rate
This monitor returns the number of bytes drained per millisecond from CommsMgr Receive Queue.
Receive Queue Size
This monitor returns the number of bytes in CommsMgr Receive Queue.
Send Queue Drain Rate
This monitor returns the number of bytes drained per millisecond from CommsMgr Send Queue.
Send Update Queue Size
This monitor returns the number of bytes in CommsMgr Send Update Queue.
TCP Port: Client
This monitor tests the ability of a Failover Engine client to accept incoming sessions. By default, it monitors TCP port 52267.
By default, this monitor is disabled.
Warning and Error Events: Interceptor Driver
This monitor returns the number of Interceptor Drivers error and warning events.
Source name: Nfid.
Log name: System.
Warning and Error Events: Packet Filter
This monitor returns the number of Packet Filter errors and warning events.
Source name: NFPktfltr.
Log name: System.
Warning and Error Events: Failover Server
This monitor returns the number of Failover Server errors and warning events.
Source name: NFServerR2.
Log name: Application.
