Documentation forOrion Platform
Upgrade Multiple SolarWinds Products (deprecated)
Updated September 18, 2018 | SolarWinds Upgrade Guide
This topic has been deprecated. See Install or upgrade products in an existing Orion deployment (2016.1 through 2018.4 deployments) for information about upgrades.
Does the installer say you are running a legacy version? See Upgrade older versions of Orion Platform products
With the new SolarWinds Orion installer, upgrades have never been easier. If you have the following minimum versions, you can upgrade multiple products by downloading one installer:
  • DPAIM 11.1
  • Engineer's Web Toolset 11.0
  • EOC 2.0
  • IPAM 4.3.1
  • NCM 7.5
  • NPM 12.0
  • NTA 4.2
  • Patch Manager 2.1.3
  • SAM 6.2.4
  • SRM 6.3
  • UDT 3.2.3
  • VMAN 7.1
  • VNQM 4.2.3
  • WPM 2.2
Even if you have an older version, you can use the installer to scan your environment and provide your upgrade path. Then use the instructions below to upgrade to one of the minimum versions. After that, you can continue using the SolarWinds Orion Installer to complete your upgrade.
This guide walks you through upgrading multiple SolarWinds products in your environment. We include checklists to prepare and complete your upgrades, gotchas, and troubleshooting steps.
Upgrading only one product? See our SolarWinds single product upgrade guide!
Preflight upgrade checklist
When planning your upgrades for a multiple Orion product environment, consider the following guidelines:
Your Orion product versions must match across your Orion environment including the additional polling engine and additional web server.
If adding a new additional polling engine or additional web server, upgrade your current products then add the new scalability servers. For details on scalability options, see the SolarWinds Scalability Guidelines.
This preflight checklist details a number of important steps to help plan and prep for your upgrade.
Review release notes
Review product release notes and available documentation in our Success Center.
Review product release notes in our Success Center.
Review system requirements
Make sure your environment has all of the required hardware and software needs for your installations. You can verify the requirements for products and multi-module environments guidelines.
Product requirements include:
You may need to also check the administrator guide for your product to locate the requirements.
For all port requirements, see Port Requirements for all SolarWinds products.
Review licenses Review your current product licenses and determine if you need to make any changes. You can download any updated license keys for your upgrade through your Customer Portal. Verify any license upgrades and needs with your SolarWinds account manager or contact SolarWinds.
Do you need to migrate?
You may need to migrate products and databases to new dedicated servers or to shared servers. Check if you need to migrate by reviewing new requirements, your products, and your current environment.
Migrating adds time to your upgrade, but you have the best opportunity to update to new servers during an upgrade.
Gather credentials Make sure you have all account credentials, SQL database credentials, your SolarWinds account, and local admin server credentials.
Build your upgrade path
Use the SolarWinds Orion Installer to build your upgrade path. Even with older product versions, you can use the Orion Installer to build a detailed, accurate upgrade path.
The Product Upgrade Advisor is still available, but it does not include all product versions. For this reason, SolarWinds recommends using the Orion installer.
Run all Windows updates Before upgrading, check for and run all Microsoft Windows Updates on your main polling engine, all additional polling engines, and all additional web servers. As you upgrade, if a Windows update runs, your system may reboot as needed by Windows.
Schedule the upgrade Set up the maintenance window, preferably off-peak hours. Depending on the number of products, size of database(s), and size of environment, you may need hours to complete your upgrade.
Upgrades will require polling engines and SolarWinds services to be offline for a length of time, causing you to lose a portion of polling data.
Notify your company Send a message to your company of the upgrade schedule and maintenance window. If you need additional help, contact and allocate specific staff to be available.
How long does an upgrade take?
The time it takes to complete an upgrade depends on:
  • Hardware
  • Database server performance and database size
  • Number of additional polling engines
  • Number of additional web servers
  • Environment performance
  • Number of modules being upgraded
  • Number of devices being polled
Since every configuration is different, we cannot predict exactly how long your upgrade will take. Through this guide, we include steps and tips to help reduce the time for your upgrade.
Gotchas you should review
For product-specific gotchas, check the following guides:
General Orion Platform gotchas
  • Orion Platform 2020.2 products are compatible with Windows Server 2012 R2.
  • Orion Platform 2018.4 - 2019.4 products are no longer compatible with Windows Server 2012 and 2012 R2.
  • Orion Platform 2020.2 products are compatible with Windows SQL Server 2012.
  • Orion Platform 2018.4 - 2019.4 products are no longer compatible with any version of SQL Server 2012.
  • If you wrote your own code, by changing SolarWinds .css files or adding .js files, or were directed to make changes by SolarWinds Support, the code may be overwritten during the upgrade. See Upgrading if you have custom code.
  • Always check that you have enough hard drive space for zipped and unzipped installers. One unzipped installer can consume several GBs of space.
  • During your upgrade, use the Scalability Engine Installer. If you use downloaded installers or the installer bundle, you must install one product and version at a time. The versions must match between the main and additional polling engines or you will receive a Database Configuration Failure Error.
  • If upgrading from a very early or End of Life SolarWinds product version, you may want to install a new product instead of performing an upgrade or migrating data. SolarWinds Support can provide the best advice for these upgrade scenarios.
  • If you enabled SolarWinds High Availability, you must disable High Availability before you can upgrade. You must have the same versions of SolarWinds products on your primary and secondary servers before you can re-enable your HA pools. See Upgrade with HA.
  • Orion Platform 2016.1 products have new port requirements: 5671 (Rabbit MQ messaging), 17791 (agent communication to 2008 R2 SP1), 17778 (SW Information Service, agent communication to 2012).
  • Orion Platform 2016.1 products no longer support Windows Server 2003, 2008, 2008 SP1, or 2008 R2 without SP1.
  • If you have NPM, upgrade NPM first. NPM includes platform features to support all Orion products.
  • If you have SAM without NPM, upgrade SAM first. SAM includes platform features to support all Orion products.
  • Always follow the Product Upgrade Advisor upgrade path. The typical installations of Orion product follow this order: NPM, NTA, SAM, NCM, WPM, UDT, VNQM, and onward.
Prepare your environment to upgrade
When you are ready to upgrade, complete these steps. They include the common actions you need to complete before upgrading products.
If you have a test or staging environment, we highly recommend testing the upgrade first. You cannot roll back an installation once completed.
1. Back up the DB
Snapshot your VMs
Back up your SolarWinds SQL database. If you need help, please check your vendor's site for documentation and instructions.
If you have your database on a VM, create a snapshot or copy of your VM.
You cannot roll back an upgrade. Always create a database backup.
2. Back up custom code (Optional)
(Optional) Back up your custom code. When upgrading, any custom additions or changes to the interface will be saved over.
3. Back up Report Writer reports (Optional)
Upgrading to an Orion Platform 2016.1 or later product? You can skip this step.
If you use Report Writer reports (NPM 10.5 and earlier) or still have legacy reports, back up the reports folder to save your custom reports:
  • 64-bit OS: C:\Program Files x86\Solarwinds\Orion\Reportsx86\Solarwinds\Orion\Reports
  • 32-bit OS: C:\Program Files\Solarwinds\Orion
4. Exclude files on anti-virus software
To ensure the best performance on your server host and provide full file access, exclude specific file paths and directories from anti-virus software scans.
You can also place your systems behind a firewall to completely disable your anti-virus software during an upgrade.
5. Stop services Stop services in the Orion Service Manager on the main polling engine, all additional polling engines, and all web servers.
6. Disable alert actions
To prevent false alert storms during upgrades, SolarWinds recommends disabling alert actions:
  1. Go to Alerts & Activity.
  2. Click More.
  3. Select Pause actions of all alerts.
Upgrade with SolarWinds HA
Upgrade with High Availability
To upgrade a server pair in a SolarWinds High Availability (HA) pool, follow the instructions for upgrading your product with the following differences.
If you enabled SolarWinds High Availability, you must disable HA before you can upgrade. All SolarWinds product versions must match on the primary and secondary servers before you can re-enable your HA pools.
These instructions assume you have an HA pool already created and enabled.
1. Disable the HA pool
The HA pool must be disabled to begin upgrading. If you upgrade prior to disabling, the pool is automatically disabled.
  1. In the Orion Web Console, click Settings > All Settings > High Availability Deployment Summary.
  2. Select the pool you want to disable.
  3. Toggle High Availability to Off.
Do not modify the VIP or IP settings for the servers.
2. Upgrade the primary server Follow the upgrade instructions in the next section for the primary server. If you need to upgrade multiple products in the upgrade path, complete those upgrades fully.
3. Upgrade the secondary server using Orion Scalability Engine Installer
Download the Orion Scalability Engine Installer on the primary server and run it on the secondary server to upgrade:
  1. In the Orion Web Console, click Settings > All Settings > Polling Engines and click Download Installer Now.
  2. Move the downloaded installer to your secondary server and run it.
  3. Complete the installation process. You may be prompted to enter your SQL credentials for your Orion SQL database.
4. Enable the HA pool
When the installer completes, enable the HA pool using the following instructions. You may need to recreate the HA pool. For details, see this article.
  2. Select the pool you want to enable.
  3. Toggle High Availability to On.
    The Orion Web Console verifies all SolarWinds product versions match across the HA pair before enabling. If you receive errors, check your product versions.
Upgrade multiple products
This checklist includes the common steps for upgrading multiple products in your environment.
If you upgrade to the latest version of some products like NPM 12.0 or later and SAM 6.2.4 and later as part of your upgrade path, you will use our improved standalone installer.
This installer runs a series of tests against the current environment and products:
  • If you need to update your environment, a list of changes with KB articles displays.
  • If you need to install additional product versions, an upgrade path with links displays. Complete any additional upgrades using the repeatable steps.
  • Re-run this installer for updates and the final product version installation.
  • When done on the main poller, complete these steps for the Additional Polling Engine and Additional Web Server. To learn about bundle and Scalability Engine install options, see Orion product installers for main poller, additional polling engine, additional web servers, and HA.
Upgrade Tip! If you upgrade multiple versions of the same product, skip the website optimization step in the Configuration Wizard. Only run this step with the last installation to save time.
1. Check for specific product upgrade gotchas
If you have specific product upgrades with significant changes in databases or install locations, make sure to complete those additional instructions and steps during this upgrade. You can check specific product upgrade guides for detailed gotchas.
For example, NTA 4.0 through 4.2.3 requires a new Flow Storage Database be installed before installing the NTA product. You may need to review additional content for NTA:
2. Installation step using the upgrade path (Repeatable)
Following the upgrade path, download the product installation file from your Customer Portal in the My Downloads area. Save this file to your systems.
Depending on the version, you may have a smart bundle of all install files per system, separate files to download, or the standalone installer.
If you have an issue running the installer, check the following:
  • Verify the installer is not blocked. Right-click the installer file, select Properties. Check is Unblock is available and select.
  • Right-click the installer file and select Run as Administrator.
  1. Main Poller: Unzip, upgrade, and run the Configuration Wizard.
  2. Each Additional Polling Engine: Download and run the Additional Polling Engine installer, and run the Configuration Wizard. For Orion 2016.2 and later products, use the Orion Scalability Engine Installer.
  3. Each Additional Web Server: Download and run the Additional Web Server installer, and run the Configuration Wizard. For Orion 2016.2 and later products, use the Orion Scalability Engine Installer.
  4. During an additional web server upgrade, you can point users to the website of the main polling engine, or to any web server that is already upgraded.
After installing this product and version on your entire environment, check the product and version as done on your downloaded Upgrade Path PDF or list. If you have additional versions to install, repeat this step.
Recommendations: Orion Scalability Engine Installer
When you upgrade your additional polling engine (APE) and additional web server (AWS), use the unified Scalability Engine Installer if available. This new lightweight installer is far faster for upgrading your APE and AWS than installing one module at a time!
  1. Install your modules on the Main Poller. When complete, you will need to upgrade your additional polling engines and additional web servers.
  2. Download this installer through the Orion Web Console.
    • For the APE installer, click Settings > All Settings > Polling Engines.
    • For the AWS installer, click Settings > All Settings > Web Console Settings.
  3. Copy the installer to your APE or AWS.
  4. Run the appropriate installer on your APE and AWS. This single installer will upgrade all Orion modules on each of these servers. If you are upgrading one or more modules, all modules are upgraded.
4. Upgrade Orion Agents
If you have the Global Agent Setting to Allow automatic updates (enabled by default), the Orion Agents automatically upgrade in the background. Agents are tied to their release version. You can skip manually upgrading agents if the option is enabled.
The upgrades take a bit of time to complete, but will not require any actions. Agents update at a throttled number of 10 to limit the impact on the polling engine. As soon as one agent completes upgrading, another agent takes its place so there are always 10 active threads until all agents are upgraded.
If automatic upgrades are disabled, upgrade the Orion Agents:
  1. Open the Manage Agents page. Orion Agents requiring upgrades display Update Required.
  2. Select all agents needing updates and click More Actions > Update. The agents upgrade in the background.
You can enable the option through Settings > All Settings > Agent & Remote Collector and click Define Global Agent Settings.
5. Start the engines
Start services in the Orion Service Manager on the main polling engine, all additional polling engines, and all web servers.
6. Re-enable alert actions
  2. Click More.
  3. De-select Pause actions of all alerts.
If you have alerts configured to notify you when certain entities haven't been polled for "X" number of minutes or similar, ensure that you have waited at least two polling intervals before re-enabling alert actions so that polling has caught completely up, which prevents false alerts.
After the upgrade check your system
All product versions should be installed properly. Open the application and verify the versions displayed in the footer of the Web Console. Try current and new features with your system to check performance and expected functionality. If you run into issues, check the troubleshooting tips.
Troubleshooting
If you receive errors, try the following:
  • If you experience issues and are not on the latest product versions, we recommend completing a full upgrade. Use the SolarWinds Orion Installer to create the upgrade path. Many of these updates solve issues you may experience part way through your upgrade.
  • Check our Success Center for troubleshooting. We recommend searching the name of the product, the version number, any error codes or messages displayed, and the general issue you found.
  • Check your Customer Portal for any new hot fixes.
  • If you receive a (500) internal server error after an upgrade, use the Orion permission checker to make sure your Group Policy is not locked. See this article for full details.
  • If your views do not load when first opening the console, run the Configuration Wizard again.
If an issue occurs you need additional help with, contact Support. We recommend gathering diagnostics, a screenshot of the issue, and any error codes you receive. Attach and add this information to your ticket. You may also want to gather additional diagnostics on your additional polling engines and web servers.
Legal notices
© 2021 SolarWinds Worldwide, LLC. All rights reserved.
This document may not be reproduced by any means nor modified, decompiled, disassembled, published or distributed, in whole or in part, or translated to any electronic medium or other means without the prior written consent of SolarWinds. All right, title, and interest in and to the software, services, and documentation are and shall remain the exclusive property of SolarWinds, its affiliates, and/or its respective licensors.
SOLARWINDS DISCLAIMS ALL WARRANTIES, CONDITIONS, OR OTHER TERMS, EXPRESS OR IMPLIED, STATUTORY OR OTHERWISE, ON THE DOCUMENTATION, INCLUDING WITHOUT LIMITATION NONINFRINGEMENT, ACCURACY, COMPLETENESS, OR USEFULNESS OF ANY INFORMATION CONTAINED HEREIN. IN NO EVENT SHALL SOLARWINDS, ITS SUPPLIERS, NOR ITS LICENSORS BE LIABLE FOR ANY DAMAGES, WHETHER ARISING IN TORT, CONTRACT OR ANY OTHER LEGAL THEORY, EVEN IF SOLARWINDS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
The SolarWinds, SolarWinds & Design, Orion, and THWACK trademarks are the exclusive property of SolarWinds Worldwide, LLC or its affiliates, are registered with the U.S. Patent and Trademark Office, and may be registered or pending registration in other countries. All other SolarWinds trademarks, service marks, and logos may be common law marks or are registered or pending registration. All other trademarks mentioned herein are used for identification purposes only and are trademarks of (and may be registered trademarks) of their respective companies.
