Documentation forHybrid Cloud Observability Advancedand NetFlow Traffic Analyzer
NetFlow Traffic Analyzer 2019.4 System Requirements
The system requirements for SolarWinds NTA 2019.4 provide the following sections:
For additional information about requirements and configurations, see the Multi-module system guidelines. You should also review your product administration guides and release notes for the exact product requirements beyond these minimums.
Polling engine requirements
The following requirements ensure the scalability benefits of SolarWinds NTA:
Type Requirements
Operating system
Microsoft Windows Server 2016
Microsoft Windows Server 2019
SolarWinds NPM
Version 2019.4
SolarWinds NTA requires an appropriate SolarWinds NPM version hosted on the same server.
Databases
NTA and Orion Platform use two databases - the Orion database and the NTA SQL Flow Storage database. The Orion database stores SolarWinds Orion configuration data and all collected performance and syslog data. The NTA Flow Storage database is where SolarWinds NTA stores your flow data.
The NTA SQL Flow Storage database requires an instance of Microsoft SQL Server 2016 SP1 or later. Both databases can be collocated on one SQL server. For more information, see What are the hardware recommendations for the NTA SQL Flow Storage database.
In case you decide to use separate SQL servers for the Orion database and the NTA SQL Flow Storage database, the Orion database requires Microsoft SQL Server 2014 and later.
A connection to Orion SQL database is required because CBQoS data and some additional low level details are still stored in Orion SQL database.
SQL server requirements
SolarWinds NTA utilizes two SQL databases:
  • The Orion database
  • The NTA SQL Flow Storage database
SolarWinds supports both the Orion database and the NTA SQL Flow Storage database in the same SQL server instance, as long as that instance is SQL Server 2016 SP1 or later. See sections below for Orion database requirements and the NTA SQL Flow Storage database requirements.
You cannot install Orion Platform products on the same server as SolarWinds Access Rights Manager (ARM).
NTA Flow Storage database requirements
The table below lists software and hardware requirements for your SolarWinds Orion database server using SolarWinds NPM license levels.
  • Multiple SolarWinds Orion server installations using the same database are not supported.
  • If you install on a virtual machine, you must maintain your SQL Server database on a separate, physical drive.
Requirements SL100, SL250, SL500 SL2000 SLX
SQL server
SolarWinds supports Express, Standard, or Enterprise versions of the following:
  • SQL Server 2016, 2016 SP1, or 2016 SP2
  • SQL Server 2017
SolarWinds strongly recommends using the 64-bit version of SQL Server.
  • Due to latency effects, SolarWinds does not recommend installing your SQL Server and your Orion server or additional polling engine in different locations across a WAN.
  • You can set the database recovery model to Full Recovery if you use Always On Availability. SolarWinds recommends Simple database recovery mode to ensure best performance.
SQL Server collation
  • English with collation setting SQL_Latin1_General_CP1_CI_AS
  • German with collation setting German_PhoneBook_CI_AS
  • Japanese with collation setting Japanese_CI_AS
  • Simplified Chinese with collation setting Chinese_PRC_CI_AS
We support CI database on an CS SQL Server.
We do not support case-sensitive databases.
CPU speed
Quad core processor or better
Dual quad core processor or better
Hard drive space
20 GB minimum
40 GB recommended
50 GB minimum
100 GB recommended
100 GB minimum
400 GB recommended
SolarWinds recommends the following configuration:
  • A hardware RAID Controller with a battery backed-up write back cache
  • Disk Subsystem 1 Array 1: 2x 146 GB 15K disks RAID 1 (mirroring) for the OS
  • Disc Subsystem 2 Array 2: 2x 146 GB 15K disks RAID 1 (Pagefile + Extra Storage)
  • Disk Subsystem 3 Array 3: with 6x 15k 146 GB or 300 GB disks configured in a RAID 1+0 array for your SQL MDF and FILEGROUPS.
  • Disk Subsystem 4 Array 4: with 4x 15k 146 GB or 300 GB disks configured in a RAID 1+0 array for your SQL LDF Transaction LOG file
  • Disk Subsystem 5 Array 5: with 4x 15k 146 GB or 300 GB disks configured in a RAID 1+0 array for your tempdb data file
  • Disk Subsystem 6 Array 6: with 4x 15k 146 GB or 300 GB disks configured in a RAID 0 array for your tempdb log file
  • Due to intense I/O requirements, a RAID 1+0 drive is strongly recommended for the SolarWinds database, data, and log files with a dedicated drive for the server operating system and tempdb files.
  • Other RAID configurations can negatively affect your SQL Server's performance.
  • Mirrored drives for the OS and RAID 1+0 for database data files are recommended.
  • Solid state drives (SSD) are recommended for all components.
Per Windows standards, some common files may need to be installed on the same drive as your server operating system. You may want to move or expand the Windows or SQL temporary directories.
Memory
SL100
8 GB minimum
16 GB recommended
16 GB minimum
64 GB recommended
64 GB minimum
128 GB recommended
SL250 &SL500
8 GB minimum
16 GB recommended
Authentication
Either mixed-mode or Windows authentication. If you require SQL authentication, you must enable mixed mode on your SQL server.
Other software
If you are managing your SolarWinds Orion database, SolarWinds recommends you install the SQL Server Management Studio component.
The Installation wizard installs the following required x86 components if they are not found on your Orion database server:
  • SQL Server System Common Language Runtime (CLR) Types. Orion products use secure SQL CLR stored procedures for selected, non-business data operations to improve overall performance.
  • Microsoft SQL Server Native Client
  • Microsoft SQL Server Management Objects
Cloud instance requirements for the NTA SQL Flow Storage database in Azure
Instance Details Medium (SL2000) Large (SLX)
Instance type D12_v2 D15_v2
CPU 4 CPU 16 CPU
RAM 30.5 GB RAM 122 GB RAM
Disk System SSD 80 GB (included in D12_v2) + Data Azure Storage Disk Volume 500 GB (8 GB for every received sustained 1000 Flows/s with 30-days retention period) System SSD 320 GB (included in D12_v2) + Data Azure Storage Disk Volume 2.5 TB (2.5 TB is Flow Storage, 300k FPS with 30-days retention, Azure Storage Disk with Provisioned IOPS recommended)
Virtual machine requirements
SolarWinds NTA may be installed on VMware Virtual Machines and Microsoft Virtual Servers if the following conditions are met in your virtual environment:
SolarWinds NPM uses SNMP to monitor your network. SNMP traffic is generally assigned low priority, and thus you can experience gaps in monitoring data.
Port requirements
The following table lists ports that SolarWinds NetFlow Traffic Analyzer uses to communicate with other devices and servers.
Port Protocol Service/Process Direction Description
80 TCP World Wide Web Publishing Service Bidirectional Port used for web console and any other web servers.
137 UDP NetBIOS Outbound
Port for outbound traffic if NetBIOS name resolution is turned on.
When NTA is trying to resolve the NetBIOS names of servers in their conversations, you may find a large amount of outbound UDP 137 traffic from the NTA collector to a number of external addresses. You can confirm the traffic by using the Flow Navigator to match the outbound connections to existing conversations.
This is normal behavior when NetBIOS is enabled. An easy way to demonstrate the behavior is to disable NetBIOS in NTA and watch all outbound connections terminate.
161
UDP
TCP
SolarWinds Job Engine v2 Outbound Port used for sending and receiving SNMP information, including polling CBQoS-enabled devices.
1433 TCP
SolarWinds NetFlow Service
SolarWinds NetFlow Storage Service
Outbound Port used for communication between the NetFlow Service and the existing SQL server.
1434
UDP
SQL Browse Service
Outbound The port used for communication between the NetFlow Service and the Orion database. This port is required only if your SQL Server is configured to use dynamic ports.
2055 UDP SolarWinds NetFlow Service Inbound Port for receiving flows on any SolarWinds NTA collector.
5671 TCP RabbitMQ Bidirectional Rabbit MQ messaging.
17777 TCP SolarWinds Information Service Bidirectional
Port for sending and receiving traffic between SolarWinds NPM and other Orion Modules.
Port used for communication between remote Flow Storage Database and NTA Main Poller.
17778 HTTPS and TCP SolarWinds Information Service Bidirectional Open to access the SolarWinds Information Service API and agent communication.
17791 TCP SolarWinds Agent Bidirectional Open for agent communication on any SolarWinds Orion server running Windows Server 2016.
Device-specific       Any port required by a specific device.
For a complete list of the port requirements for the SolarWinds Orion server, see the Port Requirements document.
