Documentation forNetFlow Traffic Analyzer
Analyzing network traffic and bandwidth is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Advanced edition. NetFlow Traffic Analyzer (NTA) is also available in a standalone module.
NetFlow Summary filtered view
Using the Flow Navigator, you can customize a filter that will enable you to display specified network traffic according to your needs.
  1. Click My Dashboards > NetFlow > NTA Summary.
  2. Click Flow Navigator on the left edge of the summary view. The Flow Navigator is available on any default NTA view.
  3. Under View Type, click Summary, and then select NetFlow Summary.
  4. Select the Time Period over which you want to view network traffic.
  5. Select a Flow Direction.
  6. You can also further limit the view by including or excluding some of the following items:
  7. Click Submit.
  8. If you want to save your custom filtered view for future reference, click Save Filtered View to Menu Bar.
