Documentation forNetFlow Traffic Analyzer
Analyzing network traffic and bandwidth is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Advanced edition. NetFlow Traffic Analyzer (NTA) is also available in a standalone module.
IP Address Group Conversation filtered view
Using the Flow Navigator, you can customize a filter that will enable you to display network traffic associated with a specified conversation of IP address groups.
  1. Click My Dashboards > NetFlow > NTA Summary.
  2. Click Flow Navigator on the left edge of the summary view. The Flow Navigator is available on any default NTA view.
  3. Specify the View Type.
    1. If you want a filtered view of all IP address groups across your network, click Summary, and then select IP Address Groups.
    2. If you want a filtered view of an IP group, click Detail, and then select IP Address Group.
    3. Specify the IP address group:
      • Select the Node for which you want to monitor network traffic attributed to an IP address group.
        If you select a node here, you can specify only Ingress or Egress for the Flow direction. Selecting Both results in applying the flow direction default for the appropriate view.
      • Select the Interface for which you want to monitor network traffic attributed to an IP address group.
      • If you want to further limit the view, specify the appropriate IP address group from the list.
  4. Select the Time Period over which you want to view network traffic of the selected IP address group(s).
  5. Select a Flow Direction.
  6. You can also further limit the view by including or excluding some of the following items:
  7. Click Submit.
  8. If you want to save your custom filtered view for future reference, click Save Filtered View to Menu Bar.
