IPFIX on Extreme Networks x460
This configuration works on EXOS 15.3 and newer. You may receive the following error on earlier versions:
NetFlow Receiver Service [servername] received an invalid IPFIX template with ID 265 from device.
configure ip-fix ip-address xxx.xxx.xxx.xxx protocol udp L4-port 2055 vr "VR-Default" configure ip-fix source ip-address xxx.xxx.xxx.xxx vr "VR-Default" configure ip-fix ports 47 ingress-and-egress enable ip-fix ports 47 ipv4 configure ip-fix ports 48 ingress-and-egress enable ip-fix ports 48 ipv4 Show ip-fix Global IPFIX State: Enabled Domain: 0 Source (Exporter) IP: xxx.xxx.xxx.xxx Virtual Router: "VR-Default" Collector IP: xxx.xxx.xxx.xxx Transport Protocol/Port/State: UDP, Port 2055, NA Flow Keys: IPv4: "Source-IP" "Source L4 Port" "Dest-IP" "Dest L4 Port" "L4 Protocol" "TOS" Unused: IPv6: "Source-IP" "Source L4 Port" "Dest-IP" "Dest L4 Port" "Next Header" "TOS" "Flow Label" Unused: Non-IP: "Source MAC" "Dest MAC" "Ethertype" "VLAN ID" "Priority" "Tagged" Unused: IPFIX Enabled on Port(s): 47-48
