Conversation Total Transferred Bytes
This widget displays a chart that details the total number of bytes that are both transmitted and received during conversations over a specified period of time.
When placed on the Node Details or Interface Details view, this widget provides a view of the total bytes transferred during conversations utilizing the viewed node or interface over the selected period of time.
Edit the widget
If you are logged in using a User ID with administrative privileges, you can change the way this widget is displayed for all users:
- Click Edit to load the Edit Resource page.
- Make changes.
- Click Submit.
Edit time and flow direction for the view
You can also change the time period and flows direction shown by all widgets in the view:
- Directly below the view name, click next to the appropriate setting and define the appropriate settings.
- Change the Relative Time Period, by default set to 1 hour prior to the current time, or specify a specific time period.
The time and flow direction settings are limited to the current session only. After you leave the view, your changes will be lost and default settings are re-applied.
