Cisco ASA 5500
Besides the usual target address for flow exports, devices in this series require a service policy that enables flow data to be exported.
The following example includes annotations that explain the requirements for successfully configuring NetFlow on this device.
ip flow-export destination inside 1.1.1.1 2055
This command sets the export target IP address and port and designates it as inside the network that includes the ASA device.
ip flow-export template timeout-rate 1
This command sets the timeout of the current v9 template (in this case: one minute) and results in resending the template with the flow data as soon as the timeout is reached.
ip flow-export delay flow-create 60
This command delays the creation of a NetFlow record and so delays exporting flow data until the number of seconds (60 in this case) are reached.
ip access-list netflow-export extended permit ip any any
This command creates an access-list
called netflow-export that the device uses to export flow records from any IP address outside interface to any IP address (in this case, the result is that exports go to the NetFlow collector target as specified in the ip flow-export destination
command).
class-map netflow-export-class match access-list netflow-export policy-map global_policy class netflow-export-class service-policy global_policy global flow-export event-type all destination 1.1.1.1
If a global policy already exists, add the NetFlow policy map to it.
These commands create the Modular QoS traffic management setup to enable flow packet traffic to get out of the device's outside interfaces and make it to the targeted NetFlow collector:
- Creates a traffic class (
class-map
) callednetflow-export-class
. - Specifies that the access list
netflow-export
should be applied (match
) to this class. - Selects (
policy-map
) default traffic inspection rules (global_policy
) for flow traffic. - Applies (
service-policy
) those rules to all interfaces (global
) on the device through which flow packets is transferred. - Specifies that all events that trigger creation of flow records should be targeted at the NTA collector (1.1.1.1).
Full configuration
The overall configuration without annotations looks like this:
flow-export destination inside 1.1.1.1 2055 flow-export template timeout-rate 1 flow-export delay flow-create 60 access-list netflow-export extended permit ip any any class-map netflow-export-class match access-list netflow-export policy-map global_policy class netflow-export-class flow-export event-type all destination 1.1.1.1 service-policy global_policy global
