Flexible Netflow on Cisco 6509
Compare your switch configuration with the following configuration of Flexible NetFlow v5 on a 6509E device and consider adjusting your configuration accordingly:
! flow record ORION-FLOW match ipv4 tos match ipv4 protocol match ipv4 source address match ipv4 destination address match transport source-port match transport destination-port match interface input collect interface output collect counter bytes collect counter packets collect timestamp sys-uptime first collect timestamp sys-uptime last ! flow exporter ORION-EXPORTER description NETFLOW Export to ORION destination xxx.xxx.xxx.xxx source Loopback0 transport udp 2055 export-protocol netflow-v5 ! flow monitor ORION-MONITOR description ORION Netflow Monitor record ORION-FLOW exporter ORION-EXPORTER ! interface vlan xxxx ip flow monitor ORION-MONITOR input ip flow monitor ORION-MONITOR output !
