Cisco 6509 native IOS global configuration
! mls ip multicast flow-stat-timer 9 mls aging long 64 mls aging normal 32 mls flow ip interface-full mls nde sender version 5 ! ip flow ingress layer2-switched vlan xxxx (separate each VLAN with a comma) ip flow-export source (port/interface with the IP address that is being monitored in Orion) ip flow-export version 5 ip flow-export destination IP_Address (Orion NPM server) 2055 !
CEF must be enabled on some devices in order for NTA to work properly.
Layer 3 interfaces
ip route-cache flow
VLANs
ip flow ingress
