Documentation forNetFlow Traffic Analyzer
Analyzing network traffic and bandwidth is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Advanced edition. NetFlow Traffic Analyzer (NTA) is also available in a standalone module.
CBQoS Pre‑Policy Class Map (Classic Chart)
If this widget is displayed on any Interface Details view, the CBQoS Pre-Policy Class Map widget provides both a graph and a table detailing the progress of traffic corresponding to defined classes passing through the viewed interface prior to the application of any policy maps.
If this widget is displayed on the CBQoS Details view, the CBQoS Pre-Policy Class Map widget provides both a graph and a table detailing both the average and the most recently polled amount of traffic corresponding to the selected CBQoS policy class passing through the viewed interface prior to the application of any policy maps.
Edit the widget
If you are logged in using a User ID with administrative privileges, you can change the way this widget is displayed for all users:
  1. Click Edit to go to the Edit widget page.
  2. Make the appropriate changes.
  1. Click Submit.
Edit the widget for the current session
You can change the contents and looks of the widget for the current session only. After you leave the view, your changes will be lost and default settings applied.
Chart Style and Data Units
  1. In the Data drop-down, select the appropriate chart style (Area Chart or Pie Chart).
  2. If you have selected the Area Chart type, you can further select what data you want to display by the widget.
    1. In the Data Units drop-down, select the appropriate unit.
Time Period and Flows Direction
To change the time period and Flows direction shown by all widgets in the view, click next to the appropriate setting below the view name and define the settings.
For more information about time settings, see Edit time settings for NTA views.
For more information about Flow direction settings, seeEdit flow direction in NTA views.
