Documentation forNetFlow Traffic Analyzer
Analyzing network traffic and bandwidth is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Advanced edition. NetFlow Traffic Analyzer (NTA) is also available in a standalone module.
CBQoS Post-Policy Class Map
If this widget is displayed on any Interface Details view, the CBQoS Post-Policy Class Map widget provides both a graph and a table detailing the progress of traffic corresponding to defined classes passing through the viewed interface resulting from the application of policy maps on the viewed interface.
If this widget is displayed on the CBQoS Details view, the CBQoS Post-Policy Class Map widget provides both a graph and a table detailing both the average and the most recently polled amount of traffic corresponding to the selected CBQoS policy class passing through the viewed interface resulting from the application of policy maps on the viewed interface.
Edit the widget
If you are logged in using a User ID with administrative privileges, you can change the way this widget is displayed for all users:
  1. Click Edit to load the Edit Resource page.
  2. Make changes.
  3. Click Submit.
Edit time and flow direction for the view
You can also change the time period and flows direction shown by all widgets in the view:
  1. Directly below the view name, click next to the appropriate setting and define the appropriate settings.
  2. Change the Relative Time Period, by default set to 1 hour prior to the current time, or specify a specific time period.
The time and flow direction settings are limited to the current session only. After you leave the view, your changes will be lost and default settings are re-applied.
