Documentation forNetFlow Traffic Analyzer
Analyzing network traffic and bandwidth is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Advanced edition. NetFlow Traffic Analyzer (NTA) is also available in a standalone module.
CBQoS filtered view
Using the Flow Navigator, you can customize a filter showing traffic connected with specified CBQoS policies used on your interfaces.
You can view both CBQoS policies that are active at the moment and historical policies that are not applied any more. For more information about CBQoS views, see CBQoS Details View.
CBQoS policies that are not used any more are stored in the database according to your retention settings. After the retention period, the policies are deleted and you cannot display them anymore. For more information about setting the retention period, see Common Database Settings.
  1. Click My Dashboards > NetFlow > NTA Summary.
  2. Click Flow Navigator on the left edge of the summary view. The Flow Navigator is available on any default NTA view.
  3. Define the View Type:
    1. Select Detail.
    2. Under Detail View Type, select CBQoS.
    3. Use the Node and Interface lists to select the interface relevant for the CBQoS policy.
    4. Select a CBQoS Class Map. Brackets behind the CBQoS Class Map name show the time when the corresponding policy was applied on the selected interface.
  4. Select the Time Period when the CBQoS policy was applied.
  5. Select a Flow Direction.
  6. If you want to save your custom filtered view for future reference, click Save Filtered View to Menu Bar.
