Documentation forNetFlow Traffic Analyzer
Analyzing network traffic and bandwidth is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Advanced edition. NetFlow Traffic Analyzer (NTA) is also available in a standalone module.
Autonomous System Conversations filtered view
Using the Flow Navigator, you can customize a filter that will enable you to display traffic connected with a specified autonomous system conversation.
  1. Click My Dashboards > NetFlow > NTA Summary.
  2. Click Flow Navigator on the left edge of the summary view. The Flow Navigator is available on any default NTA view.
  3. Specify the View Type:
    1. Click Detail, and then select Autonomous System Conversations.
    2. Select the Node for which you want to monitor network traffic attributed to an autonomous system conversation.
      If you select a node here, you can specify only Ingress or Egress for the Flow direction. Selecting Both results in applying the flow direction default for the appropriate view.
    3. If you want to further limit the view, specify the Interface for which you want to monitor network traffic attributed to an autonomous system conversation.
    4. Specify the autonomous systems conversation: Fill in IDs of appropriate autonomous systems involved in the conversation.
  4. Select the Time Period over which you want to view autonomous systems conversation traffic.
  5. Select a Flow Direction.
  6. You can also further limit the view by including or excluding some of the following items:
  7. Click Submit.
  8. If you want to save your custom filtered view for future reference, click Save Filtered View to Menu Bar.
