SolarWinds NTA system requirements
Supported Version: SolarWinds NetFlow Traffic Analyzer (NTA) 4.2.3 and earlier.
The following sections list minimum system requirements and recommendations for your SolarWinds NetFlow Traffic Analyzer server.
For additional technical requirements, see the following:
Installing multiple Orion Platform products on the same computer may change the requirements. For details on multi-module environments, see the Multi-module system guidelines. For more information about sizing NetFlow Traffic Analyzer to your network and options, contact the SolarWinds sales team or visit www.solarwinds.com.
Polling engine requirements
The following table lists software requirements and recommendations for a NetFlow Traffic Analyzer installation.
SolarWinds strongly suggests using the recommended hardware configuration to avoid potential performance issues caused by a heavy load or custom configurations such as increased data retentions or more frequent polling intervals.
  • SolarWinds does not support installing NetFlow Traffic Analyzer on domain controllers.
  • SolarWinds neither recommends nor supports the installation of any Orion product on the same server or using the same database server as a Research in Motion (RIM) Blackberry server.
Type Requirements
Operating system
Production Evaluation Only
  • Windows Server 2012, and 2012 R2. IIS must be installed.
  • Windows Server 2016
  • Windows 8.1 (except for Standard Edition)
  • Windows 10
Installing NTA on Windows Server 2012 R2 Essentials is not supported.
If you have more than one poller, make sure they are all installed on 64-bit operating systems.
SolarWinds NPM Version 12.2
Operating system languages
  • English
  • German
  • Japanese
  • Simplified Chinese
IP address version
Web server
Microsoft Internet Information Services (IIS), version 7.5 or later
  • DNS specifications require that host names be composed of alphanumeric characters (A-Z, 0-9), the minus sign (-), and periods (.). Underscore characters (_) are not allowed. For more information, see RFC 952 - DOD Internet Host Table Specification.
  • The SolarWinds installer installs IIS. You can install this software manually to reduce your installation time or network bandwidth.
  • SolarWinds products are not compatible with IIS version 6.0 installations that use web gardens.
.NET Framework
.NET 4.6.2
Compatible with 4.6.1
Be sure that you are running the same version of .NET on your primary server and any additional polling engines or web servers in the environment.
Web console browser
  • Microsoft Internet Explorer version 11 or later with Active scripting
  • Microsoft Edge
  • Firefox 45.0 or later (Toolset Integration is not supported on Firefox)
  • Chrome 49.0 or later
  • Safari for iPhone
Other
MSMQ, RabbitMQ
Services
The following services must be running after installation is complete to collect syslog messages and traps:
  • SolarWinds Syslog Service
  • SolarWinds Trap Service
User privileges
SolarWinds recommends that administrators have local administrator privileges to ensure full functionality of local SolarWinds tools. Accounts limited to the Orion Web Console do not require administrator privileges.
NTA Flow Storage Database requirements
SolarWinds NTA stores NetFlow data in the NTA Flow Storage Database. The following table lists the minimum hardware requirements for the NTA Flow Storage Database.
Recommendations
  • Install the NTA Flow Storage database on a different server than the SolarWinds Orion database.
    This way, the high amount of incoming flows do not affect the performance.
  • In case you want to use SAN storage, please make sure your environment meets the IOPS requirements for the NTA Flow Storage Database server.
  • Solid-state drives (SSD) are recommended for all components.
  • Do not install the NTA Flow Storage Database on a polling engine because it might affect performance. Additional polling engine is not supported.
  • Use a dedicated disk or LUN for storing your flow data.
    We do not recommend installing the NTA Flow Storage Database on the C:\ drive.
  • Do not run anti-virus software or any other file scanning application over data in the NTA Flow Storage Database. File scanning applications affect the database performance and may even prevent the database from running properly.
    You can also review antivirus exclusions for all Orion products. For more information, see Files and directories to exclude from antivirus scanning.
Type Requirements
CPU 3 GHz or faster
Evaluation requires 2 CPUs
Production environments require 4 CPUs or more (4 - 16 CPUs)
RAM Evaluation requires 8 GB or more
Production environments require 16 GB or more (16 - 128 GB)
To ensure optimal performance, you should increase RAM together with the database size.
Hard drive space
20 GB on 7200 RPM disk or more
With the default 30-day retention period and default top talker optimization that records only those flows that represent conversations requiring the most bandwidth on your network, you should plan at least 8 GB of additional storage capacity per sustained 1000 flows per second. The required hard drive space strongly depends on your flow traffic, and SolarWinds recommends you provide more space accordingly.
NTFS file system required
The only RAID configurations that should be used with SolarWinds NTA are 0 or 1+0. Other RAID or SAN configurations are not recommended, as they can result in data loss and significantly decreased performance.
OS
64-bit operating system: Microsoft Windows Server 2008 SP2 and later
.NET Framework
4.6.2
If it is not already installed, .NET Framework auto-installs with the SolarWinds NTA Flow Storage Database
Virtual machine requirements
You can install SolarWinds NTA on VMware Virtual Machines and Microsoft Virtual Servers if the following conditions are met in your virtual environment:
SolarWinds NPM uses SNMP to monitor your network. SNMP traffic is generally assigned low priority, and thus you can experience gaps in monitoring data.
Orion SQL database requirements
Your NetFlow Traffic Analyzer and your SolarWinds Orion SQL database should use separate servers.
Multiple Orion Platform products installations using the same database are not supported.
The following table lists software and hardware requirements for your Orion SQL database server using NetFlow Traffic Analyzer license levels as a reference.
Requirements SL100, SL250, SL500 SL2000 SLX
SQL Server
SolarWinds supports Express, Standard, or Enterprise versions of the following:
  • SQL Server 2012, 2012 SP1, 2012 SP2, or 2012 SP3 (also with AlwaysOn Availability Groups)
  • SQL Server 2014 (also with AlwaysOn Availability Groups) or 2014 SP1
  • SQL Server 2016
  • SQL Server 2017
  • SolarWinds strongly recommends using 64-bit version of SQL Server.
  • The FullWithSQL installer package automatically installs SQL Server 2016 Express. This is recommended for evaluations.
  • Due to latency effects, SolarWinds does not recommend installing your SQL Server and your SolarWinds server or additional polling engine in different locations across a WAN. For more information, see this SolarWinds Knowledge Base article.
  • Both Windows Integrated Authentication and SQL authentication mechanisms are supported.
  • If you are managing your Orion database, SolarWinds recommends you install the SQL Server Management Studio component.
  • You can set the database recovery model to Full recovery mode only if you use Always On Availability. We strongly recommend Simple recovery mode to ensure best performance.
SQL Server collation
  • English with collation setting SQL_Latin1_General_CP1_CI_AS
  • German with collation setting German_PhoneBook_CI_AS
  • Japanese with collation setting Japanese_CI_AS
  • Simplified Chinese with collation setting Chinese_PRC__CI_AS
We support CI database on a CS SQL Server.
We do not support case-sensitive databases.
CPU speed
Quad core processor or better
Dual quad core processor or better
Hard drive space
20 GB minimum
40 GB recommended
50 GB minimum
100 GB recommended
100 GB minimum
400 GB recommended
SolarWinds recommends the following configuration:
  • A hardware RAID Controller with a battery backed-up write back cache
  • Disk Subsystem 1 Array : 2x 146 GB 115K disks RAID 1 (mirroring) for the OS
  • Disk Subsystem 2 Array 2: 1x 146 GB 15K disks RAID 1 (Pagefile + Extra Storage)
  • Disk Subsystem 3 Array 3: with 6 x 15K 146 GB or 300 GB disks configured in a RAID 1+0 array to allow for maximum write performance for your SQL MDF and FILEGROUPS
  • Disk Subsystem 4 Array 4: with 4x 15K 146 GB or 300 GB disks configured in a RAID 1+0 array to allow for maximum write performance for your SQL LDF Transaction LOG file
  • Disk Subsystem 5 Array 5: with 4x 15k 146 GB or 300 GB disks configured in a RAID 1+0 array to allow for maximum write performance for your tempDB data file
  • Disk Subsystem 6 Array 6: with 4x 15k 146 GB or 300 GB disks configured in a RAID 0 array to allow for maximum write performance for your tempDB LOG file
  • Due to intense I/O requirements, a RAID 1+0 drive is strongly recommended for the SolarWinds database, data, and log files with a dedicated drive for the server operating system and tempdb files.
  • Other RAID configurations can negatively affect your SQL Server's performance.
  • Mirrored drives for the OS and RAID 1+0 for database data files are recommended.
  • Solid state drives are recommended for all components except the OS drive.
Windows standards may require you install common files on the same drive as your server operating system.
Memory
SL100
4 GB minimum
8 GB recommended
SL250 & SL500
8 GB minimum
16 GB recommended
16 GB minimum
64 GB recommended
64 GB minimum
128 GB recommended
Additional memory improves both performance and reliability.
Memory and Additional Pollers Each additional poller requires 16 GB of additional RAM. For example, NTA plus 2 additional pollers would require 32 GB of RAM. 3 additional pollers would require 48 GB of RAM, and so on.
Authentication
Other software
If you are managing your Orion SQL database, SolarWinds recommends you install the SQL Server Management Studio component.
The Installation Wizard installs the following required x86 components if they are not found on your Orion database server:
  • SQL Server System Common Language Runtime (CLR) Types. Orion products use secure SQL CLR stored procedures for selected, non-business data operations to improve overall performance.
  • Microsoft SQL Server Native Client
  • Microsoft SQL Server Management Objects
