SolarWinds NTA port requirements
Supported Version: SolarWinds NetFlow Traffic Analyzer (NTA) 4.2.3 and earlier.
Review and open ports for NetFlow Traffic Analyzer to support communication for the main polling engine, Orion SQL server, additional polling engines, web server, and additional web server. These ports include feature specific requirements including Orion agents, High Availability, and component monitors and templates.
Port Protocol Service/
Process
Direction Description Encryption
80 TCP World Wide Web Publishing Service
Bidirectional
Port used for web console and any other web servers.
137 UDP NetBIOS Outbound
Port for outbound traffic if NetBIOS name resolution is turned on. When NTA is trying to resolve the NetBIOS names of servers in their conversations, you may find a large amount of outbound UDP 137 traffic from the NTA collector to a number of external addresses. You can confirm the traffic by using the Flow Navigator to match the outbound connections to existing conversations.
This is normal behavior when NetBIOS is enabled. An easy way to demonstrate the behavior is to disable NetBIOS in NTA and watch all outbound connections terminate.
161
UDP
TCP
SolarWinds Job Engine v2 Outbound Port used for sending and receiving SNMP information including polling CBQoS-enabled devices.
1433 TCP SolarWinds NetFlow Service SolarWinds NetFlow Storage Service Outbound Port used for communication between the NetFlow Service or NTA Flow Storage Database and the existing SQL server.
1434 UDP SolarWinds NetFlow Service SolarWinds NetFlow Storage Service SQL Browse Service Outbound The port used for communication between the NetFlow Service or NTA Flow Storage Database and the Orion database. This port is required only if your SQL Server is configured to use dynamic ports.
2055 UDP SolarWinds NetFlow Service Inbound Port for receiving flows on any SolarWinds NTA collector.
5671 TCP RabbitMQ Bidirectional Rabbit MQ messaging.
17777 TCP SolarWinds Information Service Bidirectional Port for sending and receiving traffic between SolarWinds NPM and other Orion Modules.
17778 HTTPS and TCP SolarWinds Information Service Bidirectional Open to access the SolarWinds Information Service API and agent communication.
17791 TCP SolarWinds Agent Bidirectional Open for agent communication on any SolarWinds Orion server running Windows Server 2008 R2 SP1.
Device-specific       Any port required by a specific device.
