Universal Device Poller - Select Nodes to Transform
Depending on its type, a transform may be assigned to nodes or interfaces.
- Expand the lists of nodes in the groups, and navigate to the nodes or interfaces on which you want to perform the transform.
- Select the nodes or interfaces.
- Selecting a group applies the transform to all nodes in the group. Clear boxes for nodes to which the transform should not be assigned.
- Selecting a node automatically assigns a selected transform to all interfaces on the node. Clear boxes for the interfaces to which the transform should not be assigned.
- Click Test to display the transform results for each selected device.
- Click Next.
Test Results for transforming a table poller display as a comma‑delimited list of values for each tested node. These values should be considered as a horizontally‑represented data column.
