Specifying Traffic Optimized Interfaces
You use the Orion Custom Property Editor to specify your optimized interfaces.
To label your interfaces with the Custom Property Editor:
- Launch the Custom Property Editor by clicking Start > All Programs > SolarWinds Orion > Advanced Features > Custom Property Editor.
- Click Add on the menu bar.
- Click Build a Custom Property from scratch, and then specify the following entries in the appropriate fields:
- Click OK on the Add Custom Properties window.
- Click Settings in the menu bar, and then check Interface ID on the Interface Editing tab.
- Click OK.
- Click Interfaces on the menu bar.
- If your appliance is not behind a firewall, complete the following procedure:
- Locate and copy the InterfaceID of the Inbound WAN Interface for the router. The inbound interface is connected on the WAN side of the appliance.
- Paste the InterfaceID into the OptimizedInterfaceID column of the Inbound LAN Interface of your appliance. The LAN interface receives all LAN traffic bound for a destination across the WAN.
- Repeat Steps a through b for each configuration matching this configuration.
- If your appliance is behind a firewall, complete the following procedure:
- Locate and copy the InterfaceID of the Inbound WAN Interface for the firewall. The inbound interface is connected on the WAN side of the appliance.
- Click File > Exit.
Field | Selection |
Add Property to | Interfaces |
Property name | OptimizedInterfaceID |
Property Type | Integer Number |
