VPN Connections (Edge Node Details)
On an edge Node Details view, the widget displays VPN tunnels for the edge.
This widget is supported for Meraki, Prisma, VeloCloud, and Viptela devices.To see VPN tunnel details for VeloCloud orchestrators, you need to have polling for VPN tunnels enabled. When you install 2023.1, the option is enabled by default. When you upgrade to 2023.1 from an earlier version, enable the option manually.
- Click Settings > All Settings, and then click Polling Settings.
- Scroll down to VeloCloud settings, enable the Poll VPN Tunnels box, and submit the changes.
Learn more
