Interface Poller Variables
The following are valid interface poller variables:
At least one of the CustomPollerStatus
variables from the tables below must be included in the trigger condition of all interface poller alerts.
Interface Poller Assignment variables
Interface Poller Assignment Variable |
Description |
${AssignmentName} |
User friendly name of a specific assignment in the form: <PollerName> - <NodeName> - <InterfaceName>. Interface name is '0' if this is a node poller. |
${N=SwisEntity; |
Internal unique ID (as guid) of specific assignment of a poller to a node or interface. |
${N=SwisEntity;M=InterfaceID} |
Internal unique ID of interface (as integer) in this assignment. '0' if this is a node poller. |
${N=SwisEntity;M=NodeID} |
Internal unique ID of node (as integer) in this assignment. |
${N=SwisEntity; |
Internal unique poller ID (as guid) in this assignment |
Interface Poller Status variables
Interface Poller Status Variable |
Description |
${N=SwisEntity; |
Internal unique ID (as guid) of the specific assignment of a poller to a node or interface. |
${N=SwisEntity;M=DateTime} |
Date and time poller statistic was last collected. |
${DateTimeUTC} |
UTC Date/time statistics last collected for this assignment |
${N=SwisEntity;M=Rate} |
For a poller with a MIB value type of 'Rate', this field contains numeric data collected from the OID. For a poller with a MIB value type of 'Counter', this field contains the change in the previous value as normalized to the polling interval. For a 'Raw Value' poller this field is null. |
${N=SwisEntity;M=RawStatus} |
For poller with a MIB value type 'Rate' or 'Counter', this field is null. For a poller with MIB value 'Raw Value' and an OID response value that is numeric, this field contains the numeric value. For a poller with MIB value 'Raw Value' and an OID response value that is not numeric, this field is null. For enumerations this field contains the actual numeric value returned from the OID instead of the user friendly text. Status comparisons that are numeric (greater than and less than) should use this field. Status values that are text descriptions should use the 'Status' field. |
${N=SwisEntity;M=Status} |
For a poller with a MIB value type of 'Rate' or 'Counter', this field is null. For a poller with a MIB value of 'Raw Value' this field contains the value from the OID 'cooked' according to its sub-type. Enumerations contain user friendly text instead of a numeric value returned from the OID. |
${N=SwisEntity;M=Total} |
For a poller with a MIB value type of 'Rate', this field is null. For a poller with a MIB value type of 'Counter' this field contains the change in the previously collected value. For a poller with a MIB value of 'Raw Value' this field is null. |
Interface Poller variables
Rate pollers only write to the 'Rate' field; counter pollers only write to the 'Total' and 'Rate' fields; and status pollers only write to the 'Status' field, unless they can be successfully converted to a numeric value, in which case the numeric value is also written to the 'RawStatus' field.
Interface Poller Variable |
Description |
${DefaultDisplayTimeUnitID} |
Internal unique ID of time units as represented by UI |
${N=SwisEntity;M=Description} |
Poller description |
${Enabled} |
(1) indicates poller currently up and collecting, otherwise (0) |
${Format} |
Currently unused |
${GroupName} |
User friendly name of group to which this poller belongs |
${IncludeHistoricStatistics} |
(1) indicates that every statistic collection is inserted as a new record. (0) indicates that this statistic is updated so that it only has one statistic record. |
${N=SwisEntity;M=InterfaceLastChange} |
Date and time that poller record last changed |
${LastChangeUTC} |
Date and time that poller record last changed (universal time) |
${MIB} |
Generally recognized OID name |
${NetObjectPrefix} |
(N) if this is a node poller. (I) if this is an interface poller |
${OID} |
OID used to gather information |
${ParserID} |
Internal unique ID of the parser (sub-type) of this poller, where 1=None, 2=text, 3=enum, 4=macAddress, 5=counter, 6=gauge, 10=TrueFalse, 11=FalseTrue, 12=CleanMac, 14=TimeTicks, 15=HighBandwidth, 16=AdminStatus, 17=OperationalStatus |
${N=SwisEntity; |
Poller unique ID (guid) |
${PollerType} |
(R) for rate poller, (C) for counter poller, (S) for status poller |
${SNMPGetType} |
SNMP request type (Get or GetNext) |
${TimeUnitID} |
Internal unique ID of time unit (msec/sec/min/hr/days) to which poller is normalizing |
${TimeUnitQuantity} |
Number of time units to which poller is normalizing |
${UniqueName} |
Poller user friendly name |
${Unit} |
User‑entered description of unit collected (bytes/degrees/dbs) |
