High Errors & Discards Today
The widget provides a list of monitored interfaces that have experienced data packet receiving or transmitting errors or discards exceeding the daily threshold set on theNetwork Performance Monitor Thresholds page.
To view NPM thresholds, you need administrator privileges.
Click Settings > All Settings, and then click NPM Thresholds in the Thresholds & Polling grouping.
Each interface in this widget is listed with its parent node. The status of both node and interface are indicated by status icons, where yellow is Warning Level and red is Error Level, corresponding with the thresholds set on the Network Performance Monitor Thresholds page.
Click a node or interface name to open the Details view for the selected device.
Click a reported value to display a custom chart page of the selected metric for the selected interface.
Customize the widget
Click Edit to customize the Title and Subtitle.
To limit displayed objects, enter a SQL query into the Filter field.
When you have finished your edits, click Submit.
