Active Wireless Clients
If there are any wireless clients currently connected to the access point, they will display in the Active Wireless Clients widget.
For each client, the resource provides:
- IP address
- SSID
- Signal strength
- Connected - the time the client connected
- Data rate
- Transmitted - transmitted data in bytes
- Received - received data in bytes
For Aruba Central clients, Transmitted and Received columns will show no data (0 bytes). This information is not collected to prevent exceeding the daily request limit for Aruba Central.
Customize the widget
Click Edit to customize the Title and Subtitle.
