Monitoring network performance is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. Network Performance Monitor (NPM) is also available in a standalone module.
Nodes with Problems
If there are any problems monitoring nodes, the problem nodes are listed in this widget.
The Nodes with Problems widget provides a status icon, the node name, a status description, the node's last measured response time, and a percentage measure of packet loss.
Available action
  • Clicking a node name or its status description opens the Node Details view for the selected node.
Customize the widget
Click Edit to customize the Title and Subtitle.
To limit displayed objects, enter a SQL query into the Filter field.
When you have finished your edits, click Submit.
