Monitoring network performance is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. Network Performance Monitor (NPM) is also available in a standalone module.
Nodes with High CPU Load
This widget provides a list of all monitored nodes with a measured CPU load greater than the Orion general threshold.
Nodes with high percentage packet loss are each listed with a status icon, the node name, and a percentage measure of CPU load.
Available actions
  • Click a node name to open the Details view for the selected node.
  • Click a reported CPU load percentage to open the custom CPU Load chart for the selected node.
Edit the widget
Click Edit to customize the Title and Subtitle.
To limit displayed objects, enter a SQL query into the Filter field.
When you have finished your edits, click Submit.
