NCM 7.6 Requirements
Requirements vary based on:
  • The number of nodes
  • The frequency of configuration downloads
  • The length of time that configurations are maintained in the database
Port requirements
The following ports may be needed for the Orion Web Console, depending on how NCM is set up to download and upload configurations:
Port Type Description
22 SSH/SCP
Default port for NCM to transfer configs
23 Telnet Default port for NCM to transfer configs
25 TCP SMTP email default that NCM uses for notification (If SSL/TLS encryption is set up on SMTP server, default port is 465)
69 UDP TFTP server listens on this port
80 TCP HTTP default for Orion Web Console
161 UDP SNMP statistics collection, the default for polling in NCM
162 UDP Trap messages listened for and received by the Trap Server
443 TCP Default port for HTTPS binding.
465 TCP The port used for SSL-enabled email alert actions
514 UDP Syslog Service listens for incoming messages
587 TCP The port used for TLS-enabled email alert actions
1801 TCP
MSMQ WCF binding (for more information see this article from Microsoft)
5671 TCP For encrypted RabbitMQ messaging (AMQP/TLS) into the main polling engine from all Orion servers
17777 TCP Orion module traffic. Open the port to enable communication from your poller to the Orion Web Console, and from the Orion Web Console to your poller. The port used for communication between the Orion Web Console and the poller.
17778 HTTPS Required for access to the SWIS API and agent communication
17779 HTTP SolarWinds Toolset Integration over HTTP
Ports 4369, 5672, and 25672 are opened by default. These ports can be blocked by the firewall.
Server requirements
Type
Requirements
Operating System
  • Windows Server 2012 and Windows Server 2012 R2
  • Windows Server 2016
For evaluation purposes only:
  • Windows 7 SP1
  • Windows 8 (except Standard edition)
  • Windows 8.1 including Update 1 (except Standard edition)
  • Windows 10
Installing SolarWinds Orion on Windows Server 2012 R2 Essentials is not supported.
Operating System Language
  • English
  • German
  • Japanese
  • Simplified Chinese.
NCM does not support using locales outside the group of supported operating system languages.
NCM Server Hardware
CPU Speed
3 GHz dual core dual processor
Memory
4GB
Hard Drive Space
30GB
This version of NCM holds a searchable config index on local disk that adds  6-10GB  additional disk space to the previous requirement.
Installing Windows Account
Requires administrator permission on the target server.
File System Access Permissions
Ensure the Network Service account has modify access to the system temp directory: %systemroot%\temp.
SolarWinds Orion Syslog Server
If you want real time change detection triggered through devices sending Syslog messages, the executable must have read and write access to the Orion Platform database.
SolarWinds Orion Trap Service
If you want real time change detection triggered through devices sending SNMP traps, the executable must have read and write access to the Orion Platform database.
Microsoft SNMP Trap Service
Must be installed if you want real time change detection triggered through devices sending SNMP traps.
Microsoft IIS
Version 7.5 or later. DNS specifications require hostnames to be composed of alphanumeric characters (A-Z, 0-9), the minus sign (-),  and periods (.). Underscore characters (_) are not allowed.
SolarWinds neither recommends nor supports the installation of NCM on the same server or using the same database server as a Research in Motion (RIM) Blackberry server.
Microsoft ASP .NET 2.0 Ajax Extension
Version 1 or later
If this is not found on the target computer, the setup program downloads and installs the component.
Microsoft .NET Framework
Version 4.5 (and compatible with 4.6.1)
If the required version is not found on the target computer, the setup program downloads and installs it. Ensure that .NET is turned on in Windows Features.
Database
You must create the SolarWinds Orion database with the SolarWinds Configuration Wizard. Creating the database another way is not supported.
SolarWinds supports using NCM with database servers set up in these languages: English, German, Japanese, and Chinese, but only supports storing characters in the UTF-8 set.
The following database servers are supported:
  • SQL Server 2014 and SQL Server 2014 with SP1 , and with Always On Availability Groups
  • SQL Server 2012, with or without SP1 and SP2, Standard or Enterprise
NCM local SQL database uses SQL 2014 Express.
You can use the following database select statement to check your SQL Server version, service pack or release level, and edition:
select SERVERPROPERTY ('productversion'), SERVERPROPERTY ('productlevel'), SERVERPROPERTY ('edition')
The following SQL server collations are supported:
  • English with collation setting SQL_Latin1_General_CP1_CI_AS
  • English with collation setting SQL_Latin1_General_CP1_CS_AS
  • German with collation setting German_PhoneBook_CI_AS
  • Japanese with collation setting Japanese_CI_AS
  • Simplified Chinese with collation setting Chinese_PRC_CI_AS
Your database server must support mixed-mode authentication or SQL authentication and have the following protocols enabled:
  • Shared memory
  • TCP/IP
  • Named Pipes
SQL Server 2008 Express Edition does not enable these protocols.
The following x86 components must be installed:
  • SQL Server System Common Language Runtime (CLR) Types
  • Microsoft SQL Server Native Client
  • Microsoft SQL Server Management Objects
If the components are not found on the target computer, the setup program downloads and installs the components.
Browser
  • Microsoft Internet Explorer 11 (standard and mobile views) and Microsoft Edge
  • Mozilla Firefox 45, or latest supported versions
  • Google Chrome 49, or latest supported versions
Additional information
  • The NCM Information Service requires that the Net.TCP Port Sharing service be enabled and port 17777 open for TCP traffic to the NCM server. By default, this service is disabled. The setup program sets the service to manual. Resetting the service setting to disabled is not recommended.
  • To take advantage of the numerous integration points in NCM, install the SolarWinds Engineer’s Toolset on the same server. You can also take advantage of integration points built into the Web Console by installing the Toolset on computers used to access the Web Console.
