Sample Data
You can use Loggly’s sample evaluation data if you just want to do a quick test on the features of Loggly without uploading your own data. It’s about 2MB and contains over 6,000 events. It includes a variety of sources including Apache access and error logs, Django application server logs, Java stacktraces, JSON data, and more. You can use it to try out features like filters, automated parsing, trend analysis, dashboards, and more.
Linux or Mac Environment
1. Send Data
You send data with one simple command. Open a terminal window, enter your token, then run it to upload the sample data to your account.
curl -L https://www.loggly.com/install/LogglySample.log | curl -X POST -H "content-type:text/plain" --data-binary @- https://logs-01.loggly.com/bulk/CUSTOMER_TOKEN/tag/sample
Replace:
- CUSTOMER_TOKEN: Replace with your personal Customer Token you obtain from the Source Setup pages.
You should get the response ok code. If it says "Invalid API key" then make sure to insert your customer token.
2. Verify
Search Loggly over the Last hour with the sample tag to see your log events:
tag:sample
3. Use the Data
Loggly Getting Started Guide – Use the sample data to troubleshoot problems on a website using trend analysis, dashboards, alerts and more.
Windows Environment
1. Download cURL
Download the latest version of cURL for use on your Windows machine from the cURL website. Be sure to unzip the cURL files to a directory that is easy to access (e.g. c:curl).
2. Send Data
Open the Command Prompt program from the Start menu, then change to the curl installation directory.
cd c:curl
Paste the following command into the terminal window, then run it to upload the sample data to your account.
Replace:
3. Verify
Search Loggly over the past 30 minutes with the sample tag to see your log events:
tag:sample
4. Use the Data
When the APM Integrated Experience is enabled, Loggly shares a common navigation and enhanced feature set with the other integrated experiences' products. How you navigate the product and access its features may vary from these instructions. For more information, go to the APM Integrated Experience documentation.
