Documentation foripMonitor
Create a device or group report
Device reports display monitoring results for a specific device (such as a router, server, or switch). When you run a device report, ipMonitor queries the device based on your selected report (such as CPU utilization or ping response time) and displays the results in the application. Group reports display monitoring results for all devices in a group (such as all monitors and CPU monitors).
Although you cannot edit the report parameters of a device or a group report, you can save an editable copy to My Reports where you can edit the report like any other customizable report. To save an editable version of a Quick Report, click Save to My Reports.
Device and group reports can include text, horizontal bar graphs, area graphs, and tables, based on the report. For example, when you run the CPU Utilization device report, the results display in graphical format.
When you run the CPU Utilization group report for All Monitors, the results display in a table.
To create a device or group report:
  1. Click Reports in the toolbar.
  2. In the Device Reports or Group Reports column, click a report type.
    If you select a report type that does not exist for your selection, ipMonitor will generate a blank report.
  3. Select the group or device you want to view, and click Continue.
