Documentation foripMonitor
Enable guest login
The guest login account is ideal for Network Operation Center (NOC) views because the user can log in with one click and view the dashboards. You can create a guest account that does not require login credentials.
  1. Follow the steps in Add ipMonitor user accounts to create a Guest account.
  2. In the Configuration page, click System Settings.
  3. Under User Sessions, select Enable Guest Login.
  4. Click Save.
When you log out of all sessions, a Login as Guest button displays in the user interface.
