Documentation forEngineer's Toolset
Export results
Using the Export wizard, you have several export options:
Export in the following formats:
  • Windows Metafile
  • EMF
  • BMP
  • JPG
  • PNG
  • Text
Export to the following destinations:
  • Clipboard
  • File
  • Printer
Export the object using the following height and width dimensions:
  • Millimeters
  • Inches
  • Points
Export your results
  1. Click File > Export wizard.
  2. Specify the values, and then click Export.
