Enable DPA to collect CPU metrics from a PostgreSQL instance
To enable DPA to collect CPU metrics from a PostgreSQL instance, the system_stats extension must be installed in the PostgreSQL instance. The system_stats extension is a library of stored procedures that provide access to database server metrics.
Task 1: Download and install the extension on your PostgreSQL database server
Install the extension on a Linux or macOS server
You have two options for installing the extension on a Linux or macOS server.
Option 1: Use the PGXS framework
You can build the module using the PGXS framework, which is the PostgreSQL build infrastructure for extensions.
Download the
tar.gz
file from the system_stats repository in Github. -
Move the downloaded file to an appropriate directory, and run a command such as the following to extract the contents.
tar -zxvf system_stats-1.0.tar.gz
Make sure the
PATH
environment variable includes that directory where you extracted the.tar
file. -
Compile and install the code. For example:
cd system_stats-1.0 PATH="/usr/local/pgsql/bin:$PATH" make USE_PGXS=1 sudo PATH="/usr/local/pgsql/bin:$PATH" make install USE_PGXS=1
Option 2: Use an RPM package
Go to https://download.postgresql.org/pub/repos/yum/10/redhat/rhel-latest-x86_64/ and download the following package:
system_stats_10-1.0-1.rhel8.x86_64.rpm
To install the RPM package, run the following command from a command prompt:
rpm -ivh packageName
Install the extension on a Windows server
You can build the module using the Visual Studio project file.
Download the
.zip
Extract the
.zip
file to$PGSRC\contrib\system_stats
Set the
PG_INCLUDE_DIR
andPG_LIB_DIR
environment variables to make sure the PostgreSQLinclude
andlib
directories can be found for compilation. For example:PG_INCLUDE_DIR=C:\Program Files\PostgreSQL\12\include PG_LIB_DIR=C:\Program Files\PostgreSQL\12\lib
Open the Visual Studio project file
system_stats.vcxproj
in the\system_stats
directory, and build the project.
Task 2: Install the extension in the PostgreSQL database instance
Run the following SQL command to install the extension in the PostgreSQL database instance:
CREATE EXTENSION system_stats;
Task 3: Grant permissions to the DPA user
To give DPA access to the collected metrics, add the DPA user to the monitor_system_stats
role:
GRANT monitor_system_stats to dpa_user;
