NetFlow Traffic Analyzer 4.2.2 System Requirements
SolarWinds NTA requires:
  • Appropriate SolarWinds NPM version hosted on the same server
  • NTA Flow Storage Database
  • Microsoft SQL Database
  • For production environments, SolarWinds recommends that SolarWinds NPM, Microsoft SQL Database, and NTA Flow Storage Database are hosted on separate servers.
  • SolarWinds NTA requires a 64-bit operating system.
Polling engine requirements
The following requirements ensure the scalability benefits of SolarWinds NTA:
Type Requirements
Operating system
64-bit operating system: Microsoft Windows Server 2008 and later
If you have more than one poller, make sure they are all installed on 64-bit operating systems.
SolarWinds NPM
Version 12.0
Databases
Microsoft SQL Server 2008 and later.
SQL Server 2008 Express and earlier restricts the size of any database to 4 GB. For this reason, SolarWinds does not support using SQL Server 2008 Express and earlier with SolarWinds NTA in production environments.
In SQL Server 2008 R2 Express and later, Microsoft increased the restriction of maximum database size to 10 GB. You can use these versions in production environments if your flow storage requirements do not exceed 10 GB.
The NTA Flow Storage database is where SolarWinds NTA stores your flow data. If you decide to store flows on a remote server, which SolarWinds recommends for production environments, you must install the NTA Flow Storage database there first.
A connection to Orion SQL database is required, because CBQoS data and some additional low level details are still stored in Orion SQL database.
NTA Flow Storage database requirements
The following table lists the minimum hardware requirements for the NTA Flow Storage Database which is used for storing flow data in SolarWinds NTA.
Recommendations
  • Install the NTA Flow Storage Database on a different server than the SolarWinds Orion database. This way, the high amount of incoming flows will not affect the performance.
  • Do not install the NTA Flow Storage Database on a polling engine (main or additional) because it might affect performance.
  • Use a dedicated disk for storing your flows data.
  • Check the IOPS requirements for the NTA Flow Storage Database server.
  • Do not run anti-virus software or any other file scanning application over data in the NTA Flow Storage Database. File scanning applications affect the database performance and may even prevent the database from running properly.
Type Requirements
CPU
3 GHz or faster
Evaluation requires 2 CPUs
Production environments require 4 CPUs or more (4 - 16 CPUs)
RAM
Evaluation requires 8 GB or more
Production environments require 16 GB or more (16 - 128 GB)
To ensure optimal performance, you should increase RAM together with the database size.
Hard drive space
20 GB on 7200 RPM disk or more
With the default 30-day retention period and default top talker optimization, you should plan at least 8 GB of additional storage capacity per sustained 1000 flows per second. The required hard drive space strongly depends on your flow traffic, and SolarWinds NTA recommends you provide more space accordingly.
NTFS file system required
The only RAID configurations that should be used with SolarWinds NTA are 0 or 1+0. Other RAID or SAN configurations are not recommended, as they can result in data loss and significantly decreased performance.
Operating system 64-bit Microsoft Windows Server 2008 and later
.NET Framework
4.5
If it is not already installed, .Net Framework auto-installs with the SolarWinds NTA Flow Storage database.
Port requirements
The following table lists ports that SolarWinds NetFlow Traffic Analyzer uses to communicate with other devices and servers.
Port Protocol Service/Process Direction Description
80 TCP World Wide Web Publishing Service Bidirectional Port used for web console and any other web servers.
137 UDP NetBIOS Outbound
Port for outbound traffic if NetBIOS name resolution is turned on.
When NTA is trying to resolve the NetBIOS names of servers in their conversations, you may find a large amount of outbound UDP 137 traffic from the NTA collector to a number of external addresses. You can confirm the traffic by using the Flow Navigator to match the outbound connections to existing conversations.
This is normal behavior when NetBIOS is enabled. An easy way to demonstrate the behavior is to disable NetBIOS in NTA and watch all outbound connections terminate.
161
UDP
TCP
SolarWinds Job Engine v2 Outbound Port used for sending and receiving SNMP information, including polling CBQoS-enabled devices.
1433 TCP
SolarWinds NetFlow Service
SolarWinds NetFlow Storage Service
Outbound Port used for communication between the NetFlow Service or NTA Flow Storage database and the existing SQL server.
1434
UDP
SQL Browse Service
Outbound The port used for communication between the NetFlow Service or NTA Flow Storage Database and the Orion database. This port is required only if your SQL Server is configured to use dynamic ports.
2055 UDP SolarWinds NetFlow Service Inbound Port for receiving flows on any SolarWinds NTA collector.
5671 TCP RabbitMQ Bidirectional Rabbit MQ messaging.
17777 TCP SolarWinds Information Service Bidirectional
Port for sending and receiving traffic between SolarWinds NPM and other Orion Modules.
Port used for communication between remote Flow Storage Database and NTA Main Poller.
17778 HTTPS and TCP SolarWinds Information Service Bidirectional Open to access the SolarWinds Information Service API and agent communication.
17791 TCP SolarWinds Agent Bidirectional Open for agent communication on any SolarWinds Orion server running Windows Server 2008 R2 SP1.
Device-specific Any port required by a specific device.
For a complete list of the port requirements for the SolarWinds Orion server, see the Port Requirements document.
Virtual machine requirements
SolarWinds NTA may be installed on VMware Virtual Machines and Microsoft Virtual Servers if the following conditions are met in your virtual environment:
  • Each virtual machine needs to meet the SolarWinds NPM requirements for virtual machines. For more information, see the SolarWinds Network Performance Monitor Administrator Guide.
  • Each installation of NPM should have its own dedicated network interface controller.
SolarWinds NPM uses SNMP to monitor your network. SNMP traffic is generally assigned low priority, and thus you can experience gaps in monitoring data.
Orion SQL database requirements
NPM and your SolarWinds Orion database should use separate servers.
Multiple SolarWinds Orion server installations using the same database are not supported.
Important End of Support
Microsoft SQL Server: Support for SQL 2008 and 2008 R2 is deprecated as of this release. Future releases will no longer support using SQL 2008 or 2008 R2 as your database server. SolarWinds recommends that you upgrade directly to SQL 2016 at your earliest convenience.
If you install on a virtual machine, you must maintain your SQL Server database on a separate, physical drive.
The following table lists software and hardware requirements for your SolarWinds Orion database server using SolarWinds NPM license levels.
Requirements SL100, SL250, SL500 SL2000 SLX
SQL server
SolarWinds supports Express, Standard, or Enterprise versions of the following:
  • SQL Server 2008, 2008 SP1, 2008 SP2, 2008 SP3, or 2008 SP4
  • SQL Server 2008 R2, 2008 R2 SP1, 2008 R2 SP2, or 2008 R2 SP3
  • SQL Server 2012, 2012 SP1, 2012 SP2, or 2012 SP3
  • SQL Server 2014, 2014 SP1, or 2014 SP2
  • SQL Server 2016, 2016 SP1, or 2016 SP2
    • SolarWinds strongly recommends using the 64-bit version of SQL Server.
    • The FullWithSQL installer package automatically installs SQL Server 2014 Express. This is recommended for evaluations.
    • SQL Server Compact Edition 3.5 SP2 is only supported for evaluations.
    • Due to latency effects, SolarWinds does not recommend installing your SQL Server and your Orion server or additional polling engine in different locations across a WAN. For more information, see Install SolarWinds software and SolarWinds database (SQL Server) across a WAN.
    • You can set the database recovery model to Full Recovery if you use Always On Availability. SolarWinds recommends Simple database recovery mode to ensure best performance.
SQL Server collation
  • English with collation setting SQL_Latin1_General_CP1_CI_AS
  • German with collation setting German_PhoneBook_CI_AS
  • Japanese with collation setting Japanese_CI_AS
  • Simplified Chinese with collation setting Chinese_PRC_CI_AS
We support CI database on an CS SQL Server.
We do not support case-sensitive databases.
CPU speed
Quad core processor or better
Dual quad core processor or better
Hard drive space
20 GB minimum
40 GB recommended
50 GB minimum
100 GB recommended
100 GB minimum
400 GB recommended
SolarWinds recommends the following configuration:
  • A hardware RAID Controller with a battery backed-up write back cache
  • Disk Subsystem 1 Array 1: 2x 146 GB 15K disks RAID 1 (mirroring) for the OS
  • Disc Subsystem 2 Array 2: 2x 146 GB 15K disks RAID 1 (Pagefile + Extra Storage)
  • Disk Subsystem 3 Array 3: with 6x 15k 146 GB or 300 GB disks configured in a RAID 1+0 array for your SQL MDF and FILEGROUPS.
  • Disk Subsystem 4 Array 4: with 4x 15k 146 GB or 300 GB disks configured in a RAID 1+0 array for your SQL LDF Transaction LOG file
  • Disk Subsystem 5 Array 5: with 4x 15k 146 GB or 300 GB disks configured in a RAID 1+0 array for your tempdb data file
  • Disk Subsystem 6 Array 6: with 4x 15k 146 GB or 300 GB disks configured in a RAID 0 array for your tempdb log file
  • Due to intense I/O requirements, a RAID 1+0 drive is strongly recommended for the SolarWinds database, data, and log files with a dedicated drive for the server operating system and tempdb files.
  • Other RAID configurations can negatively affect your SQL Server's performance.
  • Mirrored drives for the OS and RAID 1+0 for database data files are recommended.
  • Solid state drives (SSD) are recommended for all components.
Per Windows standards, some common files may need to be installed on the same drive as your server operating system. You may want to move or expand the Windows or SQL temporary directories.
Memory
SL100
4 GB minimum
8 GB recommended
16 GB minimum
64 GB recommended
64 GB minimum
128 GB recommended
SL250 &SL500
8 GB minimum
16 GB recommended
Authentication
Either mixed-mode or SQL authentication
Other software
If you are managing your SolarWinds Orion database, SolarWinds recommends you install the SQL Server Management Studio component.
The Installation wizard installs the following required x86 components if they are not found on your Orion database server:
  • SQL Server System Common Language Runtime (CLR) Types. Orion products use secure SQL CLR stored procedures for selected, non-business data operations to improve overall performance.
  • Microsoft SQL Server Native Client
  • Microsoft SQL Server Management Objects
