NCM 7.6 System Requirements
Requirements vary based on:
  • The number of nodes
  • The frequency of configuration downloads
  • The length of time that configurations are maintained in the database
For additional information on requirements and configurations, see the Multi-module system guidelines. You should also review your product administration guides and release notes for the exact product requirements beyond these minimums.
Port requirements
The following ports might be needed for the Orion Web Console, depending on how SolarWinds NCM is set up to download and upload configurations:
Port Protocol Service/Process Direction Description
22 SSH/SCP
SCP server
Bidirectional
SSH/SCP default port for NCM to transfer configs
23 Telnet
NCM Business Layer Plugin, NCM Jobs (collector)
Outbound Telnet default port for NCM to transfer configs
25 TCP SolarWinds Alerting Service V2 Outbound SMTP email default that NCM uses for notification (If SSL/TLS encryption is set up on SMTP server, default port is 465)
69 UDP TFTP Server Inbound TFTP server listens on this port
80 TCP IIS Inbound HTTP default for the Orion Web Console
161 UDP SolarWinds Job Engine v2 Outbound SNMP statistics collection, the default for polling in NCM
162 UDP SolarWinds Trap Service Inbound Trap messages listened for and received by the Trap Server
443 TCP IIS Inbound Default port for HTTPS binding
465 TCP SolarWinds Alerting Service V2 Outbound The port used for SSL-enabled email alert actions
514 UDP SolarWinds Syslog Service Inbound Syslog Service listens for incoming messages
587 TCP SolarWinds Alerting Service V2 Outbound The port used for TLS-enabled email alert actions
1801 TCP MSMQ Bidirectional
MSMQ WCF binding (For more information see this article from Microsoft)
5671 TCP RabbitMQ Bidirectional For encrypted RabbitMQ messaging (AMQP/TLS) into the main polling engine from all Orion servers
17777 TCP
SolarWinds Orion Module Engine
SolarWinds Information Service
SolarWinds Information Service V3
Bidirectional Orion module traffic. Open the port to enable communication from your poller to the Orion Web Console, and from the Orion Web Console to your poller. The port used for communication between the Orion Web Console and the poller.
17778 HTTPS SolarWinds Agent Inbound to the Orion server Required for access to the SWIS API and agent communication
17779 HTTP SolarWinds Toolset Inbound to the Orion server SolarWinds Toolset Integration over HTTP
Ports 4369, 5672, and 25672 are opened by default. These ports can be blocked by the firewall.
Server requirements
Do not install Orion Platform products on the same server as SolarWinds Access Rights Manager (ARM).
Type
Requirements
Operating System
  • Windows Server 2016
  • Windows Server 2012 and Windows Server 2012 R2
  • Windows Server 2008 R2, Windows Server 2008 R2 SP1
For evaluation purposes only:
  • Windows 10
  • Windows 8.1 including Update 1, 64-bit only (except Standard edition)
  • Windows 8 (except Standard edition)
  • Windows 7 SP1
Installing SolarWinds Orion on Windows Server 2012 R2 Essentials is not supported.
Operating System Language
  • English
  • German
  • Japanese
  • Simplified Chinese
NCM does not support using locales outside the group of supported operating system languages.
NCM Server Hardware
CPU Speed
3 GHz dual core dual processor
Memory
4 GB
Hard Drive Space
30 GB
This version of NCM holds a searchable config index on local disk that adds 6 - 10 GB additional disk space to the previous requirement.
Installing Windows Account
Requires administrator permission on the target server.
File System Access Permissions
Ensure the Network Service account has modify access to the system temp directory: %systemroot%\temp.
SolarWinds Orion Syslog Server
If you want real time change detection triggered through devices sending Syslog messages, the executable must have read and write access to the Orion Platform database.
SolarWinds Orion Trap Service
If you want real time change detection triggered through devices sending SNMP traps, the executable must have read and write access to the Orion Platform database.
Microsoft SNMP Trap Service
Must be installed if you want real time change detection triggered through devices sending SNMP traps.
Microsoft IIS
Version 7.5 or later. DNS specifications require hostnames to be composed of alphanumeric characters (A-Z, 0-9), the minus sign (-), and periods (.). Underscore characters (_) are not allowed.
SolarWinds does not support installing NCM on the same server or using the same database server as a Research in Motion (RIM) Blackberry server.
Microsoft ASP .NET 2.0 Ajax Extension
Version 1 or later
If this is not found on the target computer, the setup program downloads and installs the component.
Microsoft .NET Framework
Version 4.5 (and compatible with 4.6.1)
If the required version is not found on the target computer, the installer downloads and installs it. Ensure that .NET is turned on in Windows Features.
Database requirements
The Orion server and the SolarWinds Orion database must use separate servers.
If you install on a virtual machine, you must maintain your SQL Server database on a separate, physical drive.
As of Orion Platform 2018.2, you can use Amazon RDS as your database server.
Type Requirements
Language
SolarWinds supports using NCM with database servers set up in the following languages, but only supports storing characters in the UTF-8 character set.
  • English
  • German
  • Japanese
  • Chinese
SQL Server versions
  • SQL Server 2016 and SQL Server 2016 with SP1
  • SQL Server 2014 and SQL Server 2014 with SP1 or SP2, and with Always On Availability Groups
  • SQL Server 2012, with or without SP1 and SP2, Standard or Enterprise
  • SQL Server 2008 R2 without SP, 2008 R2 SP1, 2008 R2 SP2
  • SQL Server 2008 without SP, 2008 SP1, 2008 SP2, 2008 SP3
If you select the Lightweight Installation option, SQL Server Express 2014 is installed locally. This option should be used only for evaluating NCM.
You can use the following database select statement to check your SQL Server version, service pack or release level, and edition:
select SERVERPROPERTY ('productversion'), SERVERPROPERTY ('productlevel'), SERVERPROPERTY ('edition')
SQL server collations
The following SQL server collations are supported:
  • English with collation setting SQL_Latin1_General_CP1_CI_AS
  • English with collation setting SQL_Latin1_General_CP1_CS_AS
  • German with collation setting German_PhoneBook_CI_AS
  • Japanese with collation setting Japanese_CI_AS
  • Simplified Chinese with collation setting Chinese_PRC_CI_AS
Authentication and protocols
Your database server must support mixed-mode authentication or SQL authentication and have the following protocols enabled:
  • Shared memory
  • TCP/IP
  • Named Pipes
SQL Server 2008 Express Edition does not enable these protocols.
x86 components
The following x86 components must be installed:
  • SQL Server System Common Language Runtime (CLR) Types
  • Microsoft SQL Server Native Client
  • Microsoft SQL Server Management Objects
If the components are not found on the target computer, the setup program downloads and installs the components.
Supported Web Console browsers
  • Microsoft Internet Explorer 11 (standard and mobile views)
  • Microsoft Edge
  • Mozilla Firefox 45, or latest supported versions
  • Google Chrome 49, or latest supported versions
Additional information
  • The SolarWinds NCM Information Service requires that the Net.TCP Port Sharing service be enabled and port 17777 open for TCP traffic to the SolarWinds NCM server. By default, this service is disabled. The setup program sets the service to manual. Resetting the service setting to disabled is not recommended.
  • To take advantage of the numerous integration points in SolarWinds NCM, install the SolarWinds Engineer's Toolset on the same server. You can also take advantage of integration points built into the Web Console by installing the Toolset on computers used to access the Web Console.
Scalability
SolarWinds NCM 7.6 was tested for scalability in a standalone deployment of three servers: one server hosts the main server and the other two servers each host an additional polling engine. The main server manages up to 10,000 nodes, as does each additional polling engine. Therefore, the deployment supports up to 30,000 nodes total.
The standard Orion Web Console deployment has the Orion platform on the main server, polling for node status at the default rate. This deployment supports two SolarWinds NCM operations, inventory update and configuration download, performed per day on all 30,000 nodes.
Though the main server and each additional polling engine can manage up to 10,000 nodes, the actual total depends on the system hardware of the server hosts, the types of devices being monitored, and the number of jobs being run concurrently. Should you need to manage more devices, and you decide to add servers, consider consolidating your views of multiple servers with the Orion Enterprise Operations Console.
Server sizing
SolarWinds Network Configuration Manager can perform configuration management for any sized network, from small corporate LANs to large enterprise and service provider networks. Most SolarWinds NCM implementations perform well on Pentium-class 3GHz systems with 4GB of RAM using the default simultaneous transfer settings, and with no modifications to node monitoring settings.
Should scalability issues arise, adjust the following:
  • Number of simultaneous transfers
  • Frequency of uploads, downloads, and inventory jobs
  • Node polling interval for up/down monitoring
Inventory jobs may run longer than expected in larger environments. To remedy this situation, break large inventory jobs into smaller jobs that do not include as many nodes, and space these jobs over a longer period of time. Adjusting server CPU and memory will enhance user interface performance and job execution speed.
