Configuration for Loggly Single Sign On using OneLogin
Create SAML app
In the OneLogin Admin interface, navigate to Apps > Add Apps.
Search for "Loggly" and select the one with the "SAML2.0" description.
Apply desired "Display Name" and "Save".
Select "Configuration" tab and enter your subdomain.
Select "Parameters" tab and update configuration as needed. For the memberOf, choose "User Roles" and "Semicolon Delimited input" for OneLogin roles. Choose "MemberOf" and "AD/LDAP CN Extraction" for AD and other LDAP backed authentication.
Save configuration.
Configure Roles
Skip this section if you are using AD/LDAP roles/membership.
In the OneLogin Admin interface, navigate to Users > Roles
Click "New Role" to create new role. Label the role "Loggly Admins". Select "Loggly" App to Add. Select "Save" button.
Add users manually or using mappings.
Repeat steps #2 and #3 for "Loggly Users".
Note that we are using the default "Loggly Users" and "Loggly Admins". These two role name can be customized, however please let Loggly know you are using customized roles so that we can update our configuration to match the custom role names.
Provide IdP Metadata to Loggly
In the OneLogin Admin interface, navigate to Apps > Company Apps.
Select "Loggly". On the "More Action" drop down button/list, select "SAML Metadata"
Send the metadata file to Loggly.
When the APM Integrated Experience is enabled, Loggly shares a common navigation and enhanced feature set with the other integrated experiences' products. How you navigate Loggly and access its features may vary from these instructions. For more information, go to the APM Integrated Experience documentation.
