Tasks Management
The reports in this section focus on enhancing your ability to monitor the volume of work addressed by you and your team. The data presented in these fields
bring attention to:
- Possible bottlenecks and deficiencies
- Allows you to take action and
- Measure the impact of the actions taken
Tasks Throughput
When analyzing a specific field of interest, you can view how many tasks were:
- Created
- Completed
- or Remained open in a specified time frame
This information can be used to answer questions such as:
- What does my agent's performance and output look like, from the tasks workload perspective?
- How many tasks per agent are still open?
- Should the load balancing be re-evaluated?
To maximize the actionable data in these reports, you can to filter and group by:
- Source Site
- Source Department
- Assignee's Site
- Assignee's Department
- Source Object
Tasks Volume Breakdown
To further analyze your data, you can slice and dice your tasks using two fields of interest.
Select from:
- Source Site
- Source Department
- Assignee's Site
- Source Object
- What is the open task’s status distribution, per agent?
- Which requester produces the most tasks and what is their task type?
