Documentation forStorage Resource Monitor
Use SRM with SRM Profiler
In addition to the Orion Platform SRM module, there is also a separate module called SRM Profiler. This provides support for additional storage devices, and can be integrated with the SRM Orion Platform module, sharing the same license and allowing both products to run together. For more information on the SRM Profiler, see the SolarWinds Storage Manager/SRM Profiler documentation.
To integrate the SRM Orion Platform and SRM Profiler modules, you must be running version 6.0 or later for both products.
Prerequisites
The following prerequisites must be met before you can integrate SRM with SRM Profiler:
  • Open the following ports:
    • 8443
    • 17778
    • 9000
  • If your license is applied to the SRM Orion Platform module, you must reclaim the license and apply it to the SRM Profiler module before integration.
    After the SRM Orion Platform module and the SRM Profiler module are integrated, the SRM Profiler module is responsible for maintaining the license.
    SRM Integration does not support TLS 1.1 and 1.2.
The Storage Manager Integration module
The Storage Manager Integration module for Orion is specific to earlier releases of the Storage Manager. If you install the Storage Manager Integration module after the SRM Orion Platform module and the SRM Profiler module, two storage tabs become available on the Orion web page: one for the SRM Orion Platform module content, one for the SRM Profiler module content.
If you are running the Storage Manager integration module for the Orion Platform prior to integrating, SolarWinds recommends you uninstall the Storage Manager integration module first.
SolarWinds recommends that you do not install the Storage Manager Integration module after the SRM Orion Platform module and the SRM Profiler module are integrated.
