Documentation forSecurity Event Manager
LEM 6.3 system requirements
Use the following tables to plan your Log & Event Manager deployment to suit your network environment.
Server sizing is impacted by:
  • Number of nodes and network traffic. Consider event throughput and performance degradation when planning the size of your deployment. As the number of nodes and network traffic increase, the size of your deployment will need to grow with it. For example, if you are running a small deployment and begin to notice performance degradation at 300 nodes, move to a medium deployment.
  • Storing original (raw) log messages in addition to normalized log messages. If you will be storing original log messages, increase the CPU and memory resource requirements by 50%. See your hypervisor documentation for more information.
Sizing criteria
Use the following table to determine if a small, medium, or large deployment is best suited to supporting your environment.
Sizing Criteria Small Medium Large
Number of nodes
Fewer than 500 nodes in the following combinations:
  • 5 – 10 security devices
  • 10 – 250 network devices, including workstations
  • 30–150 servers
Between 300 and 2,000 nodes in the following combinations:
  • 10 – 25 security devices
  • 200 – 1,000 network devices, including workstations
  • 50 – 500 servers
More than 1,000 nodes in the following combinations:
  • 25 – 50 security devices
  • 250 – 1,000 network devices, including workstations
  • 500 – 1,000 servers
Events received per day 5M – 35M events 30M – 100M events
200M – 400M events
Note: The most successful large deployments receive up to 250M events per day.
Rules fired per day Up to 500 Up to 1,000 Up to 5,000
LEM VM hardware requirements
See "Allocate CPU and memory resources to the LEM VM" in the SEM Administrator Guide for information about how to manage LEM system resources.
Hardware on the VM host Small Medium Large
CPU
2 – 4 core processors at 2.0 GHz
6 – 10 core processors at 2.0 GHz
10 – 16 core processors at 2.0 GHz
If you will be storing original log messages in addition to normalized log messages, increase the CPU and memory resource requirements by 50%.
Memory 8 GB RAM 16 GB – 48 GB RAM 48 GB – 256 GB RAM
Hard drive storage 250GB, 15k hard drives (RAID 1/mirrored settings) 500GB, 15K hard drives (RAID 1/mirrored settings)
1TB, 15k hard drives (RAID 1/mirrored settings)
  • Installing LEM in a SAN is preferred.
  • High-speed hard drives (such as SSD drives) are required for high-end deployments.
  • Large deployments may require 1 to 2TB of storage, which you can reserve on VMware ESX(i) 4/5+ and Microsoft Hyper-V 2008 R-2/2012.
Input/output operations per second (IOPS) 40 – 200 IOPS 200 – 400 IOPS 400 or more IOPS
NIC 1 GBE NIC 1 GBE NIC 1 GBE NIC
LEM software requirements
Software Requirements
Hypervisor (required on the VM host)
One of the following:
  • VMware vSphere ESX 4.0 or ESXi 4.0 and later
  • Microsoft Hyper-V Server 2016, 2012 R2, 2012, or 2008 R2
Web browser (required on a remote computer to run the web console)
  • Google® Chrome™ 17 and later
  • Microsoft Internet Explorer® 8 and later
    Note: The web console does not run on Internet Explorer 10 on Windows Server 2012.
  • Mozilla Firefox® 10 and later
Adobe Flash (browser plug-in required on a remote computer to run the web console) Adobe Flash Player 15
Optional software (required if you want to run the desktop console on a desktop computer)
Adobe Air Runtime
For more information, visit the "What is Adobe AIR?" page: http://www.adobe.com/products/air.html.
LEM Agent hardware and software requirements
Hardware and Software Requirements
Operation System (OS)
The LEM Agent is compatible with the following operating systems:
  • IBM AIX
  • Linux
  • Mac OS X 10.7 or later
  • Oracle® Solaris
  • Windows (10, 8, 7, Vista)
  • Windows Server (2016, 2012, 2008)
The requirements specified below are minimum requirements. Depending on your deployment, you may need additional resources to support increased log-traffic volume and data retention.
CPU 450 MHz Pentium III or equivalent
Memory 512 MB RAM
Hard Drive Space 1 GB
Other requirements
Administrative access to the device hosting the LEM Agent
The LEM Agent for Mac OS X requires Java Runtime Environment (JRE) 1.5 or later.
LEM reports application hardware and software requirements
The LEM reports application is Windows only. The following Windows versions are supported:
  • Windows 10, 8, and 7
  • Windows Server 2016, 2012, 2008, 2003
Memory
512 MB RAM minimum.
SolarWinds recommends using a computer with 1 GB of RAM or more for optimal reports performance.
Other requirements Install the LEM reports application on a system that runs overnight. This is important because the daily and weekly start time for these reports is 1:00 AM and 3:00 AM, respectively.
LEM port requirements
(missing or bad snippet)(missing or bad snippet)
