Manage SEM widgets with Widget Manager: Add, edit, and more
Use the Widget Manager to create, add, edit, and delete your dashboard widgets.
About the Widget Manager
Widget Manager includes Widget Builder, which provides the tools you need to create new Primary widgets. Primary widgets are widget templates located in SEM's Widget Manager categories list. Copy a primary widget to the OpsCenter dashboard or to Monitor view to create a dashboard widget. Because all dashboard widgets operate independently of the primary widget, editing a primary widget will not impact the corresponding dashboard widget.
Using Widget Manager, you can:
- Create, edit, and delete primary widgets
- Add or delete widgets from the dashboard
To access Widget Manager, click the Ops Center view and then click Widget Manager.
This screen capture shows the "Widget manager" portion of the Ops Center view on the SEM Console:
Locate widgets
Widgets are stored in the Ops Center and Monitor views.
The Ops Center view stores all primary widgets it in the Widget Manager Categories list. Dashboard widgets cannot be stored in the Widget Manager.
The Monitor view displays primary widgets in the Widgets pane based on the filter you select as a data source. Dashboard widgets do not appear in the Widgets pane.
Add a primary widget to the dashboard
You can add a copy of a primary widget to the dashboard from the Widgets pane or Widget Builder. After you copy the widget to the dashboard, you can edit the widget as required. The original widget remains with its filter in the Categories pane.
Open the SEM legacy Flash console. See Log in to the SEM web console for steps.
On the SEM menu bar, click Ops Center.
On the Ops Center toolbar, click Widget Manager.
In the Categories pane, select a filter.
In the Widgets pane, select an available widget.
Click Add to Dashboard or drag the widget to the dashboard.
The widget is saved to the Ops Center dashboard.
To re-position the widgets on the dashboard, drag them to a new position.
Edit a dashboard widget
You can edit a dashboard widget without affecting the corresponding primary widget. During the edit, the Save to Dashboard option is disabled.
Locate a widget on the Ops Center dashboard.
On the widget toolbar, click
Edit the widget in Widget Builder as required.
Click Save.
The widget is updated based on your new settings.
Delete a dashboard widget
Widgets can only be deleted from the Ops Center. You can delete dashboard widgets directly from the dashboard.
In the dashboard, locate the widget you want to delete.
When prompted, click Yes.
The widget is deleted from the dashboard.
You can recreate the dashboard widget from the primary widget.
Open a filter from a widget
- On the dashboard, locate the appropriate widget.
- On the widget, click a chart element (line, bar, or pie wedge).
The Monitor view appears displaying the filter used for the widget data source.
If your selected item does not appear in the Monitor event grid, modify the Scope setting in the widget.
- To return to the dashboard, click Ops Center in the upper-left corner.
Move (relocate) a widget
To close the Categories and Widgets panes, click Widget Manager (if required).
Click and hold the targeted widget header.
Drag the widget to a new location.
The remaining widgets rearrange on the dashboard to accommodate the new location.
- Release the mouse button and drop the widget in the new location.
Resize a widget
To view a widget in full-screen mode, click maximize in the widget toolbar. To return the widget to its original size, click maximize
again.
To resize a widget in the dashboard, drag the bottom right corner of the widget until your desired size is highlighted in the dashboard grid. When you release the mouse button, the widget adjusts to your new size.
