Documentation forSecurity Event Manager
Visualize search results and take action with nDepth widgets and the Respond menu in SEM
This section documents how to use the Respond menu, and how to work with nDepth widgets.
For details about each nDepth widget type, also see nDepth view on the SEM Console .
About the Explore and Respond menus
The Respond and Explore drop-down menus are located at the top of the nDepth view.
Respond to an event with the nDepth Respond menu
Use the actions in the Respond drop-down menu to respond to an issue reported in your nDepth search results. For example, you can block a hostile IP address or send a user account a pop-up message if you see an unusual event.
See About SEM response actions for more information.
  1. Run a search in nDepth. See Search normalized data using nDepth search in SEM or Search raw log messages using nDepth search in SEM for help.
  2. Select a results entry, and then choose a response from the Respond menu at the top of the nDepth page.
About nDepth widgets
nDepth provides a set of default widgets similar to the widgets in the Ops Center.
Each widget represents a high-level graphical view of the specific network activity associated with your nDepth search results. The widget displays the primary items generating an activity, as well as the count (or number of incidents) for each item.
Use nDepth explorer views to create new widgets, change the look of existing widgets, add widgets to the nDepth Dashboard, and remove widgets you no longer use. Click refresh on the widget toolbar to display the latest data from your network.
View widget details
Click or point to an item in the widget to view details and statistics about the item.
A typical nDepth widget
Create a search string from a widget item
You can use items in widgets or any of the nDepth graphical tools to create new search strings, or to append existing search strings.
  1. To delete the existing search string, click on the search box.
  2. Click an item on a widget.
    A new search string associated with the widget item appears in search box.
To append an existing search string with an item from a widget, click an item on the widget. In the search box, a new search string associated with the widget item is appended to the existing search string.
Create a new nDepth widget with nDepth Widget Builder
  1. Open the SEM legacy Flash console. See Log in to the SEM web console for steps.
  2. On the SEM menu bar, navigate to Explore > nDepth.
  3. Click a view on the nDepth toolbar, such as bar charts, line charts, pie charts, or bubble charts.
  4. To open the nDepth widget builder, click on the view title bar.
  5. Complete the widget builder selections to configure the new widget.
    The new widget appears at the bottom of the chart view.
    When you configure the widget and choose the Save to Dashboard option, the new widget also appears at the bottom of the nDepth dashboard.
Edit an nDepth widget
  3. On the nDepth toolbar, click a view such as bar charts, line charts, pie charts, or bubble charts.
  4. Locate the widget you want to edit, and then click .
  5. Use the nDepth Widget Builder to reconfigure the widget.
    The updated widget appears at the bottom of the view.
  6. To refresh the widget data, click .
Add a chart widget to the nDepth dashboard
You can add an nDepth view (such as word cloud, tree view, or result details) to the nDepth Dashboard. The word cloud, tree view, and result details view display by default. If you remove a view from the dashboard, use this procedure to restore the view.
  3. To open the chart view you want to see, use the nDepth explorer toolbar.
  4. In the view, locate the chart widget you want to add to the dashboard.
  5. To add the widget to the dashboard, click on the widget toolbar.
    The widget is copied to the bottom of the nDepth Dashboard.
  6. To minimize the widget in the dashboard, click . To restore the widget, scroll down and click the widget title bar.
See also:
