Log in to the SEM admin user interface
Use the SEM admin user interface to perform the following administrator functions:
- Configure and manage LDAP and SSO settings
- Find which Active Directory groups are mapped to SEM roles
- Enable or disable user access to the console
Use a login account in the Admin Group to log into the SEM admin user interface.
Open a web browser and connect to the SEM admin user interface using the following URL:
https://<sem_manager_IP_address>:8443/mvc/login
If you have not yet activated SEM, or if you reopened port 8080, use the following URL:
http://<sem_manager_IP_address>:8080/mvc/login
You can use the command line to configure these settings by entering
admin
at thecmc>
prompt. -
Log in using your Active Directory credentials, or enter administrator credentials in the user name and password fields, and then click Login.
The default user name and password is
admin
.Your login screen will vary depending on the options you selected during setup.
