Configure High Availability settings
This topic applies to all Orion Platform products except for SolarWinds ETS.
This Orion Platform topic applies only to the following products:
ACM — APM — DPAIM — EOC — IPAM — LM — NAM — NCM — NOM — NPM — NTA — SAM — SCM — SRM — UDT — VMAN — VNQM — WPM
wiki.page("Success_Center/Reusable_content_-_InfoDev/Orion_Core_topic_indicators", "HA")
Click Settings > All Settings > High Availability Settings to access these options.
By default, High Availability is enabled and an email is sent when a failover occurs. You can change the default interval and modify your default email settings.
Default interval to consider a member as down in a pool
Define how long the active pool member can be down before a failover occurs. Provide the interval in seconds.
Email me when server status is changed
Choose to receive email messages when a failover occurs. This is enabled by default and uses the default email settings to send notifications. High Availability notifications do not depend on the SolarWinds alerting service or the Orion database, so you still receive High Availability alerts when the service or database is down.
Email me when facility status is changed
Receive email messages when the status of a low-level component changes, such as the percent used of the CPU or RAM. Facilities are used to gauge the health of the system and may trigger a failover condition. For example, the computer may restart and failover if the CPU stays over 100% for a significant amount of time.
SolarWinds recommends disabling this setting due to a potentially large message volume.
Email me when resource status is changed
Receive email messages when a SolarWinds Orion component changes, such as the polling or job engines. Resources are generally SolarWinds-specific processes or services that are monitored by the High Availability software that can trigger a failover condition. For example, if the job engine is down and does not restart successfully, the active server fails over to the standby server.
