Page Settings/Summary:
Use anchor points to change the shape of object links on Network Atlas maps. Network Atlas is a feature of SolarWinds Orion platform.
Suggested Tags:
Network Performance Monitor, NPM, Network Atlas, links, map
template('/Template:SWI-Author_Bar');
Reshape map links
You can use anchor points to change the shape of object links on your map. Use multiple anchor points to create more complex shapes and curves.
  1. Select in the Tools group, or click the middle mouse button.
  2. Click and drag the link you want to reshape.
