Page Settings/Summary:
Start Network Atlas and create a map. Network Atlas is a feature of SolarWinds Orion platform.
Suggested Tags:
Network Performance Monitor, NPM, Network Atlas, start, map
template('/Template:SWI-Author_Bar');
Start Network Atlas
Users must have the Map Management right in SolarWinds NPM or in Orion EOC.
  1. Log in to the computer hosting your Network Atlas installation.
  2. Start Network Atlas in the SolarWinds program folder.
  3. Connect to your primary Orion server:
    1. Provide your Orion Web Console user name and password.
    2. Provide the IP address or hostname of your primary Orion server in the Address field.
    3. If you are connecting to an SolarWinds NPM server, select Orion as the Connect To target.
    4. If you are connecting to an Orion EOC server, select EOC as the Connect To target.
    5. Click Connect.
  4. Now on the Network Atlas Welcome screen, select what map you want to open:
    • To open a recent map, select it in the Open Recent section.
    • To open a map available in a certain location, click Browse and navigate to the map.
    • To create a new network map, click Network Map in the Create New section. See Create network maps.
    • To create a wireless heat map, click Wireless Heat Map in the Create New section. See Create wireless heat maps.
