Page Settings/Summary:
In Orion Web Console network maps, you can see when values polled by a custom UnDP poller on a device exceed warning and critical thresholds. UnDP is a feature of SolarWinds NPM.
Suggested Tags:
Network Performance Monitor, NPM, UnDP, Universal Device Poller, custom monitor, map, Network Atlas, Orion Web Console
template('/Template:SWI-Author_Bar');
View UnDP status on maps
In the Orion Web Console network maps, you can see when a Universal Device Poller on a device returns values that exceed the warning and critical thresholds.
  1. Create a Universal Device Poller in the UnDP application.
  2. Assign the poller to nodes.
  3. Define warning or critical thresholds specifying when you want the pollers to be highlighted.
  4. Create a network map in the Network Atlas, drag the UnDPs into it, and save the map. For more information, see Create network maps.
  5. To add a UnDP on a map, start the Network Atlas, navigate to a node on which the UnDP is enabled (Vendor > Node Name > Custom Node Poller), and drag the poller into the map.
  6. Log into the Orion Web Console, go to the map view.
  7. Locate the Map resource (or add it if not available), click Edit and select your map.
You can now see UnDPs for your nodes in the Orion Web Console map. When the polled UnDP values exceed the warning threshold, the UnDP icon turns yellow on the map. After reaching the critical threshold, the icon turns red.
